      09-28-2017, 06:45 PM   #1
jaye944
Drives: a
any fridge guys out there
Hey help a brother out
Fridge warm, freezer working (bottom freezer)
noticed fridge was 17 degs
freezer was chock full
diagnostics below
There are 2 dials in fridge marked fridge - freezer (marked 1-9), fridge's dial starts from 0 and from memory I think thats the defroster, fridge switch turns the fan on
* Removed all foods
* Freezer is fine
* Fan in freezer works and turns on/off
* in "ceiling of freezer" looks like a small vent that is unblocked
* Fridge
* Crisper has vents no cold air coming through
* Top of fridge VENT (no cold air coming out) no fan behind there either just a vent
Took apart as much as I could can't see any blockages
Wondering if just leaving it overnight to "unblock any ice will help
pics below
1ST PIC freezer
2nd pic top of fridge
rest bottom where crisper is
      09-28-2017, 06:59 PM   #2
Spa2k
Drives: '13 JCW
Needs a system charge, compressor is failing and can't cool both compartments or coils on back or under fridge are so dirty system is overheating due to lack of air circulation. First thing I'd do is unplug fridge and clean coils with a soft brush - not a vacuum cleaner, because one wrong move with a hose tool can break the coils. Be gentle! Then plug it in, set the dials in the middle of the range, let it run overnight and check the temperatures in the morning. Look for 0 degrees F. in the freezer and 38-40 degrees F. in the fridge. If that doesn't work and your fridge is more than 15 years old, it's probably not worth fixing and you should buy a new energy-efficient model. Just the energy savings over the next 5-7 years should pay for it.
jaye9441053.00
      09-28-2017, 07:03 PM   #3
jaye944
Drives: a
Hey man txs for the prompt reply
I noticed the following
in the 4th picture that white cover in the fridge is VERY cold
when you open the freezer door, there seems to be coolish air coming out of the vent which stops when the door is closed
gonna have a look at the coils now
      09-28-2017, 07:08 PM   #4
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
mmm I'm getting hungry! not
jaye9441053.00
      09-28-2017, 07:58 PM   #5
jaye944
Drives: a
the coils where CAKED in dust, cleaned them switched on
there doesnt again seem to have any cold coming thorugh
only when the freezer door is opened
so still think I'm dealing with a jam/in the vent ? I think (so I've read)
      09-28-2017, 08:06 PM   #6
RickFLM4
RickFLM4's Avatar
How old is it?
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      09-28-2017, 08:33 PM   #7
jaye944
Drives: a
maybe a few years old, 4/5 ish I'm thinking
just looking, the compresser fan at the bottom/below
is what was caked in dust
not the coils, going to have another look if I can get to the coils
I'm assuming there the evaporator coils?
How old is it?
      09-28-2017, 09:03 PM   #8
jaye944
Drives: a
Been doing a lot of reading on this.
need to do some logical thinging here
think first is to check
1> Damper control
in the below picture the box though I couldnt remove the cover, I'm wondering if behing it is a damper control, I didnt wanna force it.
I'm thinking that the top is not getting any cold, because it coming from below, that white box cover is very cold, so I'm guessing that the cold is getting there.
I might see about removing the cover in the freezer, to check the coils and fan and see if it is obvious that the damper is viewable from the bottom,
The problem may be two fold. 1. coils are frozen over, maybe ice has travelled up and gumed up the damper cover essentially jamming it closed.
will try that tommorow
      09-29-2017, 12:17 AM   #9
ABC99G
Drives: 2008 E92 M3 Coupe
Hi mate, I had the opposite problem with my fridge recently. Everything
in the fridge was freezing up. Turns out the little electric motor that
operates the damper between the fridge and freezer had stopped working
and left the damper in the open position. You'll have to pull out the interior
of the fridge to get to it, but, I'll bet that's your problem.
jaye9441053.00
      09-29-2017, 06:11 AM   #10
jaye944
Drives: a
txs ABC
I checked the fridge before leaving for work at 5am (so lets say 8 hours)
temp got back down to 4 deg's !
Still going to monitor it. but saved having to strip it
spoiled food I dont careless about
I use the fridge to store my insulin in
THANKS ALL
      09-29-2017, 06:25 AM   #11
TomHudson
Drives: 2011 E90 M3
Defrost the freezer.
If the freezer vents are blocked, it will affect the cooling of the fridge.
Restock and leave room for air circulation.
jaye9441053.00
      09-29-2017, 07:37 AM   #12
bimmerfrk
bimmerfrk's Avatar
Drives: Ferrari Red F83
Get one of these so you can see whats items you have or have not while at work....
jaye9441053.00
      09-29-2017, 09:02 AM   #13
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
This is what happens when you value technology over a good refrigerator.
I have a 20 year old Sub Zero that is literally magical. Fruit literally does not spoil in it.
Samsung? sure it looks cool, but the components suck
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
paliknight2182.50
      09-29-2017, 09:31 AM   #14
RickFLM4
RickFLM4's Avatar
I have seen refrigerators with those features but haven't quite figured out why they are needed / valuable.
      09-29-2017, 09:54 AM   #15
Matt@EuroJerks
Drives: 2021 Jeep Cherokee
This is the man you are looking for. He has all the answers.
Spa2k1192.50
      09-29-2017, 09:55 AM   #16
^ so wife doesn't have to TELL you what to get on your way home You should KNOW what is needed
jaye9441053.00
      09-29-2017, 10:04 AM   #17
RickFLM4
RickFLM4's Avatar
If that's all that's in the fridge, you shouldn't need an app to tell you either.
jaye9441053.00
      09-29-2017, 12:56 PM   #18
Don't you DARE go there, I have enough losing arguments at home
      09-29-2017, 01:23 PM   #19
RickFLM4
RickFLM4's Avatar
Shopping list for that fridge:
Beer and tonic water
Coca cola, gatorade, other beverages that don' look like pear juice
Beef (steaks and ground), poultry, deli
Cheese (various types)
Condiments
1/2 and 1/2
Butter or margarine
Trash bags (to throw away much of what's in the fridge)
OK I guess I see how it works...
      09-29-2017, 03:28 PM   #20
^ What, no Jalapenos??? And where's the bag of milk???
Lups get in here and fix this guy up.
      09-29-2017, 03:34 PM   #21
Lups
Lups's Avatar
11869
Drives: I don't own a car.
Rick and i have a deal. The next time a hurricane hits Finland, he is sending jalapeņos straight away.
Finland has banned all Canadian talk, so i can't by law comment on the abused milk
You're still a little new here, so I'll let you in on a little secret. Whenever Lups types gibberish, this is an opportunity for you to imagine it to be whatever you'd like it to be.
Originally Posted by Delta0311 View Post
How would you know this? Did mommy catch you jerking off to some Big Foot porn ?
      09-29-2017, 03:34 PM   #22
bimmer456
Drives: 340i
Time to get a new fancy Samsung french door fridge with water and ice service. One of those new ones with stainless steel finish and an app that lets you see inside the fridge from your phone and shop for groceries based on what the fridge tells you to buy.
