      04-04-2020, 05:28 PM   #1
GhostOne_322
GhostOne_322's Avatar
644
Drives: 24 G80 M3 CS (BSM/Red/Gold)
2024 BMW M3 CS  [9.75]
Power Washers
Anyone have a great power washer they recommend for washing the beast...
I bought one on Amazon and am very disappointed! Want something that creates lots of foam. Don't ask...
      04-04-2020, 06:58 PM   #2
boredM
Drives: Ford F-350 & Nardo F90
kranzle k1122tst
mtm pf22.2
gyeon bathe
Maverik2594500.50
all6.00
      04-05-2020, 10:32 AM   #3
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I got the Yamaha one at costco and it been great: https://www.costcobusinessdelivery.c...100351509.html
Also I use the Chemical guys foam canon & soap with it https://www.chemicalguys.com/torq-fo...ap/HOL143.html
      04-05-2020, 04:37 PM   #4
kdeleon
Drives: M5
When you say you want a great pressure washer, are you willing to spend? I agree with boredM and the Kranzle is considered the best but that washer alone is over $1000 plus you need the right foam cannon.
Which one did you get from Amazon? I have a Sun Joe that is cheap and sometimes made fun of by certain youtube folks. But as long as you get the smaller orifice in this case the smaller one for your foam canon, then you will be fine. I can get the right pressure and enough flow out of it. I paid less than $150 for my washer.
      04-21-2020, 04:41 PM   #5
Griffin337
Drives: F90 M5
Originally Posted by boredM View Post
kranzle k1122tst
mtm pf22.2
gyeon bathe
Absolutely the best way to go!!
OP: Check out "obsessed garage". They have packages and have done all of the leg work in comparing dozens of combos.
      05-14-2020, 12:41 AM   #6
pcai
pcai's Avatar
Drives: F90 M5
F90 M5  [0.00]
I got a sunjoe spx3000 from amazon and the mtm pf22.2 and i get GREAT thick foam. It has a lot to do with your foam cannon. If you got an electric pressure washer with lower GPM, you should install a 1.1mm orifice (which is included with the mtm pf22.2). Consider investing in a good foam cannon and a 1.1mm orifice (cheap) if you have an electric pressure washer. Also the soap can play a factor. I use Adam's megafoam and autofanatic 007 snowstorm and the foam i get is pretty crazy, on par with what you see on youtube.
      05-15-2020, 08:50 AM   #7
themnmd
themnmd's Avatar
Drives: 23 X5MC
I use kranzle love it
      07-02-2020, 07:01 PM   #8
Egrunt
Egrunt's Avatar
605
Drives: BMW M5 (F90), Tacoma, GTI
I have been using a Harbor Freight one for years. It works great and only cost me $79 on sale. I initially bought it just for my work bike but I now use it for all my vehicles. I have a CR Spotless (spot free filitration) connected in line with the pressure washer. I have been using it for over 4 years and it is still going strong. With that being said if it broke tomorrow I would buy another Harbor Freight pressure washer. The M5 dried in sun without wiping it down with a chamois and no water spots.
      07-05-2020, 12:31 PM   #9
zdbmw
Z
zdbmw's Avatar
Russia
53
Drives: F90 M5
Karcher K5 Compact
Works great for me
      07-19-2020, 08:15 AM   #10
shellbmb
shellbmb's Avatar
Drives: 2024 F92 M8C
I think I'm doing something wrong as I have not found foam cannons do much for me. I power washed, applied the foam, waited 5-10 minutes then washed again and was still seeing dirt.
How are you guys using your foam cannon? And are you still having to use a wash mitt?
      07-19-2020, 10:48 AM   #11
kdeleon
Drives: M5
The foam will not get the car completely cleaned even if you have a coating on the car. To get it truly clean, you will still need a wash mitt.
The details of person’s routine will vary. For me, I use it as a prewash and lubrication for the scrub. So with the car dirty, I spray as you do and let it sit then rinse off. This loosens up the dirt and gets it pretty clean without touching or rubbing the dirt into the paint, as much as possible. Then I spray again and do not rinse it off. This will be a light coating. Then using the mitt with a soapy bucket, I scrub the car. This time it is a lubrication layer as I take off the remaining dirt.
      08-03-2020, 02:35 PM   #12
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i / X7 M50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Unless you're ceramic coated or barely any dirt you always need to use a mitt. It's not magic. The stuff just helps "loosen" the direct to make it easier to clean. I rinse thoroughly. Then foam. Then go straight to mitt after it's sat for a few minutes.
Check out obsessed garages channel. He us to a of videos explaining the process. Plus sells some great gear.
'07 Yamaha R1 (sold)/'05 C230k (sold)/
'06 C55 AMG (sold)/'14 X5 50i (Dad’s now)
'20 M5
'21 X7 M50i DSE (Wife's)
      08-03-2020, 03:25 PM   #13
MikeStammer
Drives: 2021 M5C DG
2021 M5 Comp  [0.00]
i did a very similar setup. works great!
pcai368.00
