      04-19-2020, 05:16 PM   #1
Wmzorba09
Drives: Bmw M340 2020
Front end damage - repair or replace?
Family member backed into my car .. repair or replace? Must be something behind here. Strange marking.
      04-19-2020, 06:11 PM   #2
claykin
Drives: various BMW
If the plastic is torn or dented on a ridge/edge, replace it for sure. BMW body shop can give good advice.
I'm sure the family member feels awful and at same time you want to do this as inexpensively as possible. That said, what's your tolerance for a repair that may be noticeable? Meaning if the shop cannot return the bumper plastic back to original shape.
2023 840GC | 2024 i5 | 2024 530i
      04-19-2020, 06:25 PM   #3
Burrcold
Drives: 2024 M3 Comp xDrive
Replace. Plastic repairs never look good.
      04-19-2020, 06:30 PM   #4
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
That could be repaired..
If you pay to replace it, the bodyshop will just sell that bumper anyway and make back half what they already charge you to replace it.
It's up to you but it's 2020, plastic body repair have came a long way..
      04-19-2020, 07:22 PM   #5
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
That can be repaired easily. I’ve seen worse “injuries” on the bumper that were repaired to perfection.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      04-19-2020, 07:26 PM   #6
Wmzorba09
Thanks. I've consulted a body shop. Will see. I'd think it could be repaired
      04-19-2020, 07:30 PM   #7
Burrcold
If you get it repaired, you will end up with a wavy reflection where that area is. Plastic never forms back perfectly. If you are okay with that, go ahead and have it repaired. I've seen it so many times...some people can live with it and some can't stand it (especially on darker cars that, when clean, have a mirror effect).
      04-19-2020, 07:38 PM   #8
Wmzorba09
Anyone have any idea how someone would repair this?
      04-19-2020, 07:43 PM   #9
Burrcold
They'll usually warm up the area around to "pop out" as much of the plastic as possible, then use a plastic filler (similar to any other filler). Sand, sand, sand some more and then paint.
      04-19-2020, 08:32 PM   #10
Wmzorba09
Thanks. Sounds simple enough
      04-19-2020, 09:57 PM   #11
Poochie
Poochie's Avatar
Drives: 2016 M2
I scratched up a loaner car and painted it in my backyard, with a aerosol spray can and the dealer never noticed..
A professional with right tools and experience can repair that and you'll never notice the difference.
      04-19-2020, 11:09 PM   #12
Wmzorba09
Thanks. This may be a bit more complicated because there us a sharp protrusion where the damage is. It's not a flush scratch. It's cracked and protruding.
      04-19-2020, 11:16 PM   #13
Poochie
Poochie's Avatar
Drives: 2016 M2
When it is sanded, primed and painted, it will be factory smooth. I worked in a bodyshop when I was younger, I've seen worst brought back.
If the mounting tabs for the bumper didn't snap, anything can be restored.
The original bumper has a VIN plate attached to it, a replacement wouldn't. It's more ideal to preserve the original bumper, if possible.
If I was the shop and you pushed me to replace that, I would charge you for full replacement, repair and give it back to you. Everyone is happy.
Wmzorba09339.00
VipinLJ1976.00
      04-19-2020, 11:28 PM   #14
Wmzorba09
The original bumper has a VIN plate attached to it, a replacement wouldn't. It more ideal to preserve the original bumper, if possible.
Interesting. thx for the feedback 🙏 - bumper is sitting slightly crooked as a result. Hope none of the clips are broken/damaged.
      04-20-2020, 01:12 AM   #15
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Body filler a.k.a Bondo or other brand plastic filler. This is exactly the type of damage it's made for. If done properly for a small imperfection like this, the bumper should look flawless. You usually get waviness on larger or poorly done repairs.
Wmzorba09339.00
      04-20-2020, 01:41 AM   #16
Seaford
Permanently confused
1514
Drives: 840i M Sport Gran Coupe
They will now!!
      04-20-2020, 01:52 AM   #17
Poochie
Poochie's Avatar
Drives: 2016 M2
They will now!!
That was in June 2019. By now they sold that car certified pre-owned, no prior damage to some sucker.. And that's how the game goes..
Wmzorba09339.00
VipinLJ1976.00
EXE462069.00
      04-20-2020, 11:41 AM   #18
Wmzorba09
Got an estimated $760
      04-20-2020, 06:43 PM   #19
Poochie
Poochie's Avatar
Drives: 2016 M2
That sounds like a decent price to fix and color blend the adjacent panels, a replacement bumper would of cost upwards of $2,000.
      04-20-2020, 07:23 PM   #20
Burrcold
What are they doing for $760?
      04-20-2020, 07:42 PM   #21
Poochie
Poochie's Avatar
Drives: 2016 M2
A new, unpainted bumper is like $800, so that's obviously a repair quote.
      04-20-2020, 07:44 PM   #22
EXE46
EXE46's Avatar
Drives: 2020 M340i RWD Aka New E39 M5
Give it to Poochie the shade tree body repairman...
Prior's: E36, E46 x2
Poochie9073.00
