      11-08-2008, 11:39 AM   #1
takedown8
takedown8's Avatar
Drives: 2005 BMW Z4 3.0i
How to connect these cables?
This is a shot in the dark, but hopefully some of you with electrical skills will be able to help me.
I have 4 of these cables (small, internal audio/power cables) that I want to connect end to end to make one long cable. What is the easiest way to do that? Are there male-male bare pins that will connect them or a male-male cable or do I have to solder them together? (I'd prefer not since I don't know how to do that).
Thanks in advance!
      11-08-2008, 11:43 AM   #2
EZ_TUR90
Ez tur90
EZ_TUR90's Avatar
Armenia
202
Drives: M6
Jump rope? What will this cable be used for?
      11-08-2008, 01:18 PM   #3
takedown8
takedown8's Avatar
I'm trying to retrofit a steering wheel with paddles. So this wire will go from the slip ring in the steering column all the way down to the gear shift area where I will connect it to the steptronic system.
      11-08-2008, 02:59 PM   #4
MadDog
Careful, I Bite.....
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Then just cut the unneeded connectors off, splice the wires together, and electrical tape them together.
      11-08-2008, 03:01 PM   #5
ADHD
ADHD's Avatar
Drives: F30 328i
2013 F30  [0.00]
21 M540i  [0.00]
07 e90 335  [0.00]
I wouldnt use electrical tape for this application..Your better off using heat shrink!!
      11-08-2008, 03:03 PM   #6
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Electrical tape is the poor man's heat shrink. You can also solder the splices together, if you'd like. I don't see much difference to this application, however.
      11-08-2008, 05:17 PM   #7
san~man
Tired
san~man's Avatar
138
Drives: BMW-less
Solder and heat shrink.
BMW-less
