      08-14-2021, 04:45 PM   #1
BM-Dollar
Drives: BMW 528i
Question Has anyone experienced this noise from rear?
Hi Guys/Gals,
Has any of you experienced this kind of clicking noise from the rear?
Youtube Link:
it seems to be from the passenger side and it becomes more prominent when I turn left (so putting weight on the passenger rear)...What do you think is causing it? Any thoughts on tests I could do to figure it out?
2015 BMW 528i F10 (Base)
Thank you so much every one
Last edited by BM-Dollar; 08-14-2021 at 04:51 PM.. Reason: ask more clarifying questions so community can better help :)
      08-14-2021, 05:13 PM   #2
sounds like an incorrect, too long, lug bolt tapping against the emergency brake hardware inside the hub.
sometimes happens when you get new wheel and wheel hardware.
if it has just starting occurring with no new changes to car I don't know.
      08-14-2021, 06:30 PM   #3
BM-Dollar
Drives: BMW 528i
Caravaggio
thank you for your feedback. I actually changed the wheel bearing there recently.
any suggestions for making the noise go away or fix it properly?
Best,
      08-14-2021, 07:20 PM   #4
Originally Posted by BM-Dollar View Post
Caravaggio
Best,
You need to deconstruct down to the wheel bearing. Not sure but are you supposed to use a dial gauge to confirm the bearing is seated ?
You could find you forgot to tighten a caliper bolt properly, or whatever.
But definitely remove the wheel inspect and if you are able to lift the rear safety with the transmission in neutral rotate the wheel and listen.
Obviously when up a garage lift this would probably be a quick diagnosis.
      08-14-2021, 09:15 PM   #5
BM-Dollar
Drives: BMW 528i
I also found these two guys whose noise sounds super similar. Looks like their issue went away after they thoroughly cleaned the mating surfaces of wheel inside and rotor.
      08-17-2021, 12:34 PM   #6
JasonDot
JasonDot's Avatar
579
Drives: M4, X3 and 330e
This thread isn't about farts?
      08-25-2021, 05:36 PM   #7
Fuzzuki
Drives: BMW 335i Porsche Boxster Honda
Sounds like your buddy tapping two wrenches together as you drive past....LOL
      07-20-2025, 10:42 PM   #8
soontobemppskowner
Drives: F36 440i Rwd, Mperf LSD, MPPSK, 513m or 437m depending on how I’m feeling
Did you ever remedy this, dealing with it now on my rear passenger wheel, 2017 440i red
      07-20-2025, 10:55 PM   #9
sapphire black
Drives: 2019 BMW 440i
I had this issue on my 440i when i switched wheels from the stock wheels to 437m. Someone above mentioned it, but it was because I was still using the extended lugs that I had been using for the spacers with the stock wheels. Was also on the passenger side, so very likely could be interference with the e brake hardware as mentioned above. Once I went back to regular lugs the noise was gone.
While I was looking into it, it does seem that it can also be due to movement between the wheel and rotor or rotor and hub due to corrosion. BMW sells friction rings that fit between wheel/rotor/hub that supposedly solve the issue. Also it’s always always good practice to use a wire wheel and brake cleaner or wd40 to clean the hub any time you’re changing rotors.
      07-20-2025, 11:26 PM   #10
soontobemppskowner
For me it just started happening Friday night, no change, I run 513s with oem lug bolts, I’ve cleaned everything taken off the rotor, cleaned the hub and back of rotor, not sure what now, I’m suspecting axle….
      07-21-2025, 04:56 PM   #11
sapphire black
Damn that sucks its still there after all that work but at least you’re narrowing it down, hope you figure it out soon!
