      03-23-2023, 11:46 AM   #1
cjohnson3372
Drives: bmw 2003 530i
Location of headlamp ballast
I am having a problem locating the driver side headlamp ballast for a 2003 530i. Where is it located?
      03-23-2023, 01:43 PM   #2
freakystyly
Drives: F22 B58 6MT
It looks to be similar to the E90, you'll need to remove the bumper and/or headlight to get to it unfortunately. It's located on the bottom side of your headlamp assembly (somewhat large metallic rectangular box).
      03-27-2023, 06:30 PM   #3
3002 tii
3002 tii's Avatar
2741
Drives: Z4 M, X5, GX460
Usually rectangular box mounted behind or underneath headlight housing.
Edit. See pictures in this eBay listing. It’s on the back:
https://www.ebay.com/itm/13443636712...et_ver=artemis
Follow for latest mods
      03-30-2023, 05:04 PM   #4
hamza2008
Drives: Model 3
The headlamp ballast for the driver's side headlight of a 2003 BMW 530i is located behind the headlight assembly itself. You'll need to remove the headlight assembly to access the ballast, which is a small box that controls the power supply to the headlight bulb.SnapTik
