04-07-2023, 06:52 AM | #1 |
![]() ![]() ![]() ![]() 436
Rep 789
Putting car in "detailing" mode
Hi,
As the days get longer and weather gets warmer in northern hemisphere, it is time to start detailing again. I wonder if throughout the years, someone has finally discovered how to put car's interior in to "detailing mode", so to speak. Every time I go over a capacitive touch button or an iDrive controller with a microfiber, the car wakes up, reacts to my (inadvertent) inputs and messes up all the settings. Short of disconnecting all the batteries, is there a way to disable car listening for those inputs? I haven't tried it, but I think even sending the power down command wont work as it will still listen for button inputs. Last edited by Raimo5; 04-07-2023 at 03:06 PM.. |
04-07-2023, 07:49 AM | #2 |
![]() ![]() ![]() 5002
Rep 5,076
I've found if I leave the key on a bench in the garage, and not have it in my pocket, it's basically achieving what you are asking about. But if I've got it in my pocket, interesting things do happen, i.e. the locks will lock / unlock just with the water being sprayed on the car.
Might be different from one car to the next. |
04-07-2023, 08:09 AM | #3 | |
Rep 789
For interior buttons, this approach wont work. Car will wake up regardless whether the key is visible or not. |
tracer bullet5001.50 M4Tejas1113.00 |
04-07-2023, 09:24 AM | #4 |
![]() 1061
Rep 261
Maybe try opening the doors and double press the lock button. That should set the alarm and disable interior motion sensors. Not sure if it'll accomplish what you're asking, but worth a try.
23 X3MC BGM. MSS. H&R 12mm spacers
20 4Runner 18 Cayman GTS 15 Beetle Vert |
04-07-2023, 06:38 PM | #5 |
Rep 789
04-10-2023, 01:01 PM | #8 |
Rep 789
