      05-04-2023, 10:59 AM   #1
Game
Game's Avatar
8671
Drives: G80 LCI, G87 (sold)
What's your pressure washer setup?
Pressure washer (gas or electric)- Ryobi, Active, Sunjoe, Kranzle?
Hose - Uberflex, flexzilla?
Wand - MTM?
Curious to what you guys are using. I plan on upgrading my setup for maybe weekly or biweekly use so definitely don’t need a high end setup.
      05-04-2023, 11:27 AM   #2
Pheonix
2007 BMW/Z4MC  [0.00]
Pressure washer- just replaced my cheapo SunJoe with Active 2.0. I could see significant difference when using it for the Foamer.
Hose - MTM Kobrajet
Wand - MTM Hydro Acqualine.
      05-04-2023, 11:52 AM   #3
1209582
Drives: bmw
pressure washer : kranzle 1322ts
hose - kobrajet
wand - mosmatic
      05-04-2023, 12:21 PM   #4
icj_45e
Drives: 23 X5 45e
I'm using a cheap electric one ($100 - $120 range) from amazon. Also bought a cheap nozzle from amazon to replace the long wand. No complaints, works great. Doesn't throw as much foam as the nice ones i see on youtube detailing vids, but definitely sufficient for me.
      05-04-2023, 12:26 PM   #5
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I have a SunJoe but my favorite is this little red Hyper Tough pressure washer I got at Walmart for $60. Not too powerful and easy to setup/put away/move around.
      05-04-2023, 12:32 PM   #6
wdb
dances with roads
wdb's Avatar
5375
AR Blue Clean. Comes with foam gun, hose is supple enough for me. I use all of the stuff that came with it. I think they may have a newer model out.
https://www.amazon.com/Blue-Clean-BC...02&sr=1-4&th=1
EDIT: to clarify -- I have model BC383HS.
      05-04-2023, 02:53 PM   #7
asianF22
asianF22's Avatar
Drives: 2020 BMW 230i
Pressure Washer Ryobi 1800 PSI - https://www.homedepot.com/p/RYOBI-18...1802/317623149
Hose PWACCS (50 ft) kink resistant, comes w/ (2) quick connects - https://www.amazon.com/PWACCS-Pressu...10&sr=8-3&th=1
Wand Sooprinse gun, added a quick connect - https://www.amazon.com/Sooprinse-Pre...03&sr=8-3&th=1
Foam Cannon Harbor Freight, changed orifice to 1.1mm
- https://www.harborfreight.com/pressu...non-58131.html
- https://www.amazon.com/Mingle-Cannon...s%2C122&sr=8-4
Game8670.50
LTainn3.00
      05-04-2023, 05:02 PM   #8
Hagasan41
Hagasan41's Avatar
Drives: 2013 E92 ///M3, 1999 E36 ///M3
Pressure washer: Kranzle 1122tst
Sprayer: Mosmatic swivel
Wand: Mosmatic
Cannon: MTM PF22
Tips: Mosmatic and MTM
Water Filter: CR Spotless mounted to wall
Fittings: MTM SS
Garden Hose: SS Jumper hose and Eley garden hose and Eley spray nozzle
      05-04-2023, 05:40 PM   #9
malvern_man
Drives: X5 M60i LCI
Pressure washer...BigBoi Washr Flo with the optional commercial grade hose upgrade
Stubby gun...MTM SGS28 with Carscope premium 25° and 40° nozzles
Wand...Mosmatic
Foam cannon...MJJC Pro V2, MTM PF22.2 and an Autobrite Direct foam cannon (probably not available outside the UK)
      05-04-2023, 06:04 PM   #10
allinon72
allinon72's Avatar
5161
Drives: 21' M5, 23' X1
Hose - MTM Kobrajet
Ditto
Patton2502954.00
Pheonix431.50
shimmy232495.00
Charles B149.00
FZZF0.00
Clark_Kent2337.50
      05-04-2023, 06:04 PM   #11
tranquility
sportscars only
tranquility's Avatar
Drives: 2011 Z4 sDrive 35i
I just use this all-in-one. Great for me.
      05-04-2023, 06:23 PM   #12
PJ1960
Drives: 2023 BMW z4
2022 BMW 530Xe  [0.00]
Is the Ryobi 2300 PSI too strong for car washing? I don't want to damage my vehicle unnecessarily.
      05-04-2023, 06:46 PM   #13
asianF22
asianF22's Avatar
My opinion, it SHOULD be fine; just depends on which color nozzle fitting you use. If I don't remember I usually do a test spray on the ground before using it on the car so you don't accidentally damage it.
I would just Google search the strengths of the various nozzle fittings before use.
PJ196045.00
      05-04-2023, 06:48 PM   #14
JustinHEMI
Not great. Not terrible
JustinHEMI's Avatar
7572
Drives: 2024 BMW X3 M40i
One of these hand held battery operated jobs. It's perfect for my needs, takes up little room, and uses the same batteries as my tools.
https://www.homedepot.com/p/RYOBI-40...052K/318615872
Current: 2024 BMW X3 M40i.
Porsche 718 GTS 4.0.
M4Tejas1113.00
FZZF0.00
      05-04-2023, 08:59 PM   #15
MattMP
OG M2 🖤
55
Drives: 2017 M2
Pressure washer: Original Active
Hose: 50' no name kinkless from amazon w/quick connects
Wand: Cheap gun w/swivel adapter + knock-off MTM extension
I'm patiently waiting for some of the cheap stuff to die/leak to upgrade but they're holding strong so far
      05-04-2023, 09:21 PM   #16
Tommysalami
Tommysalami's Avatar
564
Drives: E92 M3
Cheap Ryobi unit from home depot. Extra long hose. $15 foam cannon from amazon. Works great.
      05-05-2023, 06:16 AM   #17
grannyknot
grannyknot's Avatar
1023
Drives: 2008 Z4M coupe
Honda gas powered, 2000 psi, 2.5 gal per min.
The compressor has an adjustable regulator so the pressure can be dialed back if needed.
Also a Maxshine foam cannon.
2008 E86 M coupe
      05-05-2023, 06:24 AM   #18
chicagob5
Drives: E90 ZCP
I got a Comet 1700. I use the hose that comes with it in the integrated reel but use MTM wand + accessories with quick disconnects. Basically this package.
      05-05-2023, 08:10 AM   #19
icj_45e
Drives: 23 X5 45e
asianF22 I also have the Harbor Freight Foam Cannon, what did the orifice swap out do for you?
      05-05-2023, 08:55 AM   #20
asianF22
asianF22's Avatar
More foam. Also, it depends on the brand foam you are using as well; certain brands produce more foam than others.
      05-05-2023, 09:05 AM   #21
Theruleslawyer
Theruleslawyer's Avatar
Drives: 2019 m4
Those battery and bucket ones are interesting. I don't have a hose near the garage for some insane reason and hooking up both power and water is always a PITA.
      05-05-2023, 12:19 PM   #22
Game
Game's Avatar
8671
Hose - MTM Kobrajet
I thought the Active 2.0 was just on preorder still?
