      05-23-2023, 10:12 AM   #1
nazali
nazali's Avatar
Drives: 230 2020 vert F23
All the guy's love my buns !
Forget buns of steel, were talking the softest tastiest.
Brioche Bun's
Upped my game this weekend on the BBQ with some lovely Brioche buns, makes a big differnece !
Also I got a nice thick juicy steak, at least 2" thick, and took it to 125, let it rest and also S&P'd it and slathered on some BBQ sauce
AWESOMENESSS
one question
Wood chips... edumacate me
dual zone charcoal BBQ
where is best to put the charcoal, front or back (my top vent is at the back)
and then were best to put wood chips
in a box (do I soak them)
then on the coals or under the vent
OR do I just dump the wood chips on the coal
cheers
      05-23-2023, 10:38 AM   #2
ShopVac
Not willing to take advice
ShopVac's Avatar
Drives: F82 M4 - 6MT
I personally don't believe that 'soaking chips' does anything...but that's me.
I'd look to put them in a box or a smoker container that can have a small piece of coal light and flow through the chips on a slow burn (pellets, you would start with a torch). Whether chips or pellets, a slow even smoke that can last 2 to 3 hours is best. For pellets, use something like I have listed below
Putting wood chips on the coals directly will light and burn too quick. If putting something 'directly' on coals, use a larger chunk of wood - about fist size. Large size will give the smoke you desire.
Finally, type of wood has a lot to do with it. Mesquite and Hickory are heavy pungent woods that can easily over smoke your meats. Consider fruit woods (apple and cherry) and white oak (whiskey barrel) for BBQ.
Cheers
nazali1514.50
      05-23-2023, 10:44 AM   #3
Tommy-G
Tommy-G's Avatar
4717
Agreed, I have tried soaking the wood a few times and dont notice any difference
nazali1514.50
      05-23-2023, 11:34 AM   #4
ryan stewart
Drives: 2008 328it
Soaking doesn't gain you anything and actually can hinder the smoke ring if you're going for that. You want hot, clean smoke for proper smoking. Wood chips (or chunks of it's an efficient rig like a Kamado) on the coals, you want full heat
Smoking boxes or guns are really for cold smoking. Like desserts and cheeses.
nazali1514.50
      05-23-2023, 12:39 PM   #5
nazali
nazali's Avatar
ok got it
so do I want the coals at the back were the vent is, so I'm drawing the heat and smoke through the heat to the vent or vice versa
      05-23-2023, 01:02 PM   #6
ShopVac
ShopVac's Avatar
Originally Posted by nazali View Post
ok got it
Not sure what smoker you have...but the intention would be to draw through...but in reality, the entire inside should fill with smoke. Main part would be 'not' to put the food directly above the coals. Need indirect heat for BBQ.
Please my highly detailed MS Paint drawing
nazali1514.50
dradernh4826.00
cmyx6go17712.00
      05-23-2023, 01:33 PM   #7
nazali
nazali's Avatar
yes and thats what I exactly do and how my kettle is setup and arranged
phew
so the woodchips
1> not soaked
put in a smoker box on "top" of the coals or on the side under the food OR just laying in the kettle on top of the rack, no smoker box ?
      05-26-2023, 12:33 AM   #8
I am so disappoint. Even for Naz, I was expecting bun pics
nazali1514.50
cmyx6go17712.00
      05-26-2023, 03:31 AM   #9
eluded
2JZ-GTE
eluded's Avatar
3316
Drives: 340 6MT, others
Soaked on coals is what I used to do until I went pellet.
nazali1514.50
      05-26-2023, 05:10 AM   #10
billnchristy
Drives: 2022 M440xi GC
I use box on top of the charcoal. One thing about not soaking, if you have the lid up they will sometimes flash. I often sacrifice some beer to put them out, you don't want them on fire.
I often buy small barrels to age liquors and after a couple uses I let them dry out and disassemble and then use the staves in the smoke box.
nazali1514.50
      05-26-2023, 07:24 AM   #11
ShopVac
ShopVac's Avatar
Damn, this was my secret.
Occasionally will see real whiskey barrels that are cut in half for planters (usually once a year they'll sell at Lowes or HD). You'll know they're real by the char on the inside...and smell.
I'll take one, snap the bands off, and cut the strips into squares that I'll place directly on the coals with fruit wood.
These have been getting harder to find lately though...
