      11-16-2023, 10:44 AM   #1
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
caliper ceramic coat
i see lots of wheel ceramic coats on the market but can't seem to find a caliper ceramic coat. i noticed some vendors using wheel ceramic on calipers but how does that work with the heat cycles a caliper goes thru?
      11-16-2023, 01:19 PM   #2
chris719
Drives: '08 M Roadster
I'm not sure it makes much difference unless you are tracking the car and getting the calipers hot enough that the paint is changing color. There is no legitimate data out there, but my spray sealants hold up for a few weeks between washes on the caliper so I doubt the heat is a big deal for the resins. Maybe it does shorten lifetime, but who knows. I think people coat the caliper just because when you have the wheels off and you've cracked open a bottle of coating then why not, even if it didn't last that long. Most of the wheel coatings are really the same as the paint coatings but higher solids versions, but it has more to do with chemical resistance and ease of cleaning than temperature.
shimmy232495.00
      11-16-2023, 01:25 PM   #3
///MPhatic
Drives: OG M2 • Exige
2018 BMW M2  [9.22]
Ceramic coating is for non-tracked calipers, and in that capacity almost all of them will serve you well. There is no ceramic coat that will stand up to tracked calipers. In fact, there are very few paints/powder coats what will not degrade over time when tracked.
      11-16-2023, 01:31 PM   #4
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
so my x5 grocery getter will be fine.😂
chris7197724.00
///MPhatic15777.00
      11-16-2023, 05:02 PM   #5
malvern_man
Drives: X5 M60i LCI
I've got Gyeon Rim on my calipers.
From the Gyeon website....
Q² Rim has an endurance capability exceeding 800ºC without any damage to its original properties.
      11-16-2023, 06:11 PM   #6
chris719
I have these lingering doubts they actually test up to 800 C. The paint won't survive 800 C. Most caliper paint is rated for < 500 C.
///MPhatic15777.00
      11-16-2023, 07:11 PM   #7
///MPhatic
2018 BMW M2  [9.22]
Beyond that the heat comes from the inside, not the outside, so as the caliper paint/coating itself breaks down it's going to cause the ceramic coating to break down along with it.
chris7197724.00
      11-25-2023, 11:09 AM   #8
NoMods
NoMods's Avatar
Drives: 2022 M5
2022 M5  [10.00]
Gyeon RIMS, I even use it on my gloss black exhaust tips because of it's high temp rating
shimmy232495.00
      11-27-2023, 07:52 PM   #9
dradernh
dradernh's Avatar
4826
Drives: 2017 M240i
In 2020, a detailer put GTechniq Crystal Serum Ultra on a set of new calipers I bought. The finish has held up well, and the calipers still look like new.
shimmy232495.00
      11-28-2023, 01:37 AM   #10
Cutesydiva
Cutesydiva's Avatar
Drives: 2019 BMW 330i
Use a normal wheel ceramic coating, it will work just as well. If it's hot enough to break down the ceramic coating it will be hot enough to break down caliper paint too.
      02-08-2025, 10:23 AM   #11
im480hp
im480hp's Avatar
27
Drives: G87 2025
Gyeon ceramic coat special for wheels and brakes
      04-15-2025, 08:47 PM   #12
RandomStogies
Drives: 2022 X3 M40i
What did you use to clean and prep the caliper before applying ceramic coating? Also, did you remove the caliper completely off the rotor while working on it?
      04-16-2025, 11:27 AM   #13
im480hp
im480hp's Avatar
27
Drives: G87 2025
Cleaned it with car shampoo 2 times, dry and apply ceramic….didn”t remove caliper.
      04-22-2025, 08:10 PM   #14
sean2648
sean2648's Avatar
Drives: 2015 335i
We use GYEON Rim on all of our customer vehicles for wheels and calipers, holds up well. Can't expect it to last as long as ceramic coating on the paint though just due to the amount of heat and wear down there.
We sell it out of our store if you would like it at a cheaper cost since we offer a forum discount to everyone here as well.
'15 335 M Sport 6MT /// FBO /// Custom Tune /// Custom Interior
Instagram /// Build Thread
      05-09-2025, 11:28 PM   #15
wfoM8
Drives: 2023 M8 Competition Gran Coupe
Red Caliper Paint Touchup
Does anyone know the color of the Red Caliper for Paint Touchup?
I have a small nick I want to touchup.
