      11-22-2023, 03:18 AM   #1
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
2018 BMW X5M F85  [10.00]
films or paint...
Hello everyone, what do you think is better: painting or film?
here is an example of my car, film in 3 layers, send your projects
GOLFFRR11565.00
jllyons10115.00
      01-16-2024, 09:49 AM   #2
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
doesn't anyone want to share photos of their projects?.....((((
      01-16-2024, 12:18 PM   #3
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.70]
2014 BMW 328i  [6.83]
Is that power dome stuck on top of the film or is it functional?
      01-16-2024, 12:36 PM   #4
celsdogg
E4 Mafia
356
Drives: E30, E36/5, E46x2, F22, F30
while its not my particular cup of tea, it does look stunning with lots of attention to detail. Enjoy!
Squad - '90 E30 325i MT (226k) | '98 E36/5 318ti MT (160k) | '03 E46 325i MT (156k) | '04 E46 330xi MT (195k) | '15 F22 M235i MT (66k) | '15 F30 335i MT (85k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k)
Bring back the purple M stripe
      01-17-2024, 03:22 AM   #5
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
it was necessary so that the hood could be closed, it was done a long time ago, about 3 years ago, but it is separate, bolted from the inside to the hood
      01-17-2024, 03:24 AM   #6
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
thank you, I put a lot of effort into this car... still nerves))))
      01-17-2024, 08:38 AM   #7
celsdogg
E4 Mafia
356
can we see under the hood?
      01-17-2024, 10:04 AM   #8
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
A little later I’ll make a separate post, I’ll put it in order after tests and temporary solutions, I plan to start tuning the engine in February. Now everything was done very unprofessionally, and not very correctly... but if you want, I can show you how not to do it)))))
      01-17-2024, 10:35 AM   #9
GOLFFRR
GOLFFRR's Avatar
11565
Drives: GOLFFRR cart
thats wild!
      01-17-2024, 10:54 AM   #10
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
Originally Posted by GOLFFRR View Post
thats wild!
wildly good or wildly bad?)
      01-17-2024, 02:21 PM   #11
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
I did a little research when my clear coat failed, I read that wrap only lasts up to five years while paint can last much longer with reasonable maintenance. I found it strange how wrappers don’t want to give you a reasonable estimate and I didn’t want to play that game. I had the hood, roof and trunk lid repainted and am happy with the results.
      01-17-2024, 05:02 PM   #12
CrucialBBQs
Drives: 2007 530i
As a high line refinisher I have to say films are pretty damn awesome for customization. Also, non invasive! Paint and the subsequent labor involved is prohibitively exspensive. Often people don't want to pay what it would take to get the look you can with wraps. You still need to find good materials and a quality installer but in the end you can leave your finish intact where painting is not as reversible. Also, you can be more creative with films more so than paint. Some of the effects a creative wrap artist can create can't be duplicated in liquid.
Hornet-01245.00
      01-18-2024, 01:54 AM   #13
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
The advantages of the film are that it can be replaced, and it will protect against damage, that is, if there is a stone or a scratch, then the paint on the car will remain intact. dents can be removed without painting, new film, and everything is like new)
      01-18-2024, 02:02 AM   #14
Chilled
Chilled's Avatar
Drives: F85 X5M
What are the 3 layers.
1 Layer is the green colour
1 Layer is the under green imprint
      01-19-2024, 08:50 AM   #15
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
the same pattern is under the film, so the pattern looks more voluminous and as if it was squeezed out)
Chilled643.50
      01-19-2024, 01:42 PM   #16
hC1001
Drives: E36 M3, F80 M3
That dome on the front hood is not appealing. Would you be able to use the M5 CS hood or something instead or is it still not enough clearance?
      01-20-2024, 12:15 PM   #17
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
I'm thinking of returning the stock hood, because... Everything has already been redone, now the hump is not needed... although I’m used to it)
      01-20-2024, 01:38 PM   #18
jkoral
Drives: 2017 M2 LBB 6MT
What about the spray-able coating that peels off? Goes on like paint, peels off like film. No affiliation, just found it interesting.
https://f87.bimmerpost.com/forums/sh....php?t=1530010
Hornet-01245.00
      01-20-2024, 02:46 PM   #19
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
looks interesting, but I have a drawing on a car, I probably won’t be able to achieve this effect using autoflex
jkoral1269.00
      01-24-2024, 09:50 AM   #20
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
Chilled643.50
      02-02-2024, 02:21 PM   #21
PNW-BMW
Drives: 2009 BMW 535i
That's a beautiful color! I like sleeker looking hoods, but this is an amazing ride. Did you do it all yourself?
I was thinking about masking off a couple of designs on the side of the car, sanding down and painting but leaving the rest of the car stock paint. Do you think that would work?
      02-04-2024, 09:13 AM   #22
Hornet-01
Hornet-01's Avatar
Russia
245
Drives: BMW X5M F85
I thought for a long time about painting it or using film, but in the end I decided on film because... the color turned out as evenly as possible, this doesn’t always work out with painting... plus there are a lot of varieties of film now, you can choose it to suit any desire, limited only by your imagination.
If you do it yourself, then prepare the surface perfectly, otherwise all the flaws will be visible(
