03-11-2024, 09:26 AM | #1 |
![]() 29
Rep 15
Frozen Grey has a polished patch, how to restore?
Hi All,
Recently bought my Z4 with the frozen grey metallic. Previous owner had some tree sap on the bonnet and while cleaning it off has polished out a patch of the matte finish so it now looks like gloss. Aside from a complete re-spray, what could I do? Looking at how the paint works I was thinking I could get some matte clear coat and re-apply to the polished patch, blending to to the rest of the bonnet which is fine? Anyone else has this issue and resolved? Thanks |
03-11-2024, 09:35 AM | #2 |
![]() ![]() 8715
Rep 5,873
With a frozen color I don’t think you can do a touchup like this and you may have to repaint.
03-11-2024, 09:47 AM | #3 |
![]() ![]() 6825
Rep 5,057
I wonder if you wrapped the hood with matte ppf if it would hide that spot (while protecting your paint in that area at least)?
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
Littierally324.00 chris7197724.00 |
03-11-2024, 10:42 AM | #4 |
11562
Rep 28,221
any pics of the damage?
![]() BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY MATT FIRST! Matt Sales:mlui@bmwofcamarillo.com Cell:805-300-9713 vipfinance@bmwofcamarillo.com for warranties! |
03-11-2024, 11:00 AM | #5 |
![]() 29
Rep 15
Not currently - and its been raining for a solid 2 weeks meaning you can't see it in the wet.
The patch is in the middle of the bonnet aout the size of a hand and is only visible from certain angles. From what I can see putting a small amount of matte clear coat on should sort it but I don't want to make it worse. I've attached a photo from another forum showing how the matte efefct works, so basically the previous owner has just polished smooth the top layer of clear coat. Putting it back on should get back the matte effect. |
GOLFFRR11562.00 |
03-11-2024, 11:38 AM | #6 | |
Rep 3,953
The only way to do this is to do it properly, which is to sand the entire panel and respray the entire thing with the correct amount of matte, which may take a few tries. There is no second option that wouldn't either be visible or make it worse in one way or another. Lucky for your the stock paint is intact, and BMW has a spec for the matte, so no worries. |
03-11-2024, 02:31 PM | #7 |
Be Present
324
Rep 84
Cover the entire hood in PPF. The Xpel Stealth is almost a perfect match to the naked eye - it’s a significantly more reliable way to restore the frozen sheen. Most auto body shops do not get this right when painting.
03-11-2024, 11:13 PM | #8 | |
![]() 11
Rep 15
Aside from the huge price difference in doing the whole car 😏 |
Littierally324.00 |
03-11-2024, 11:34 PM | #9 |
Be Present
324
Rep 84
I think you will be 100% satisfied with doing the hood alone.
The benefit here is that the hood is the only horizontal structure on the front of the car, and it has hard lines separating it from the rest of the panels. The light will always reflect differently on horizontal vs vertical panels. This is to your benefit. I suspect wrapping the hood with tucked corners will cost $500-600, as opposed to 5-8x that for the entire car. My CS is frozen deep green metallic, I had the entire car wrapped in xPel Stealth - the jambs are the only raw portion of the car and I can’t see a visible difference. In my opinion, this is the easiest and most reliable route. |
03-12-2024, 07:39 AM | #12 |
![]() ![]() 8234
Rep 2,377
Drives: 2020 BMW M4 CS
I'm going to go out on a limb here and suggest that no one buys their second matte finish car? Seems the only way to get this finish to work is to buy a standard finish and then have a full car PPF. So $5,000.00 to $6,000.00 later you have a repairable matte finish car?
03-12-2024, 07:43 AM | #13 | |
Rep 3,953
I do, however, agree with PPF on a matte finish. If I ever purchase such a finish the entire car will be covered in PPF. It's the only reasonable choice IMO. |
Burrcold6825.00 f*ck trump210.00 |
03-12-2024, 08:23 AM | #14 | |
![]() ![]() 6825
Rep 5,057
///MPhatic15777.00 |
03-12-2024, 09:40 AM | #15 | |
Rep 3,953
Matte is just a PITA (if you care about keeping it nice), no way around it. |
03-12-2024, 09:44 AM | #16 |
![]() 2515
Rep 2,084
Drives: Many, BMW.
I feel like a light scrub with a new magic eraser would dull it out? lol
03-12-2024, 11:39 AM | #17 | |
Be Present
324
Rep 84
The illustration posted above shows the concept well. |
03-12-2024, 11:59 AM | #18 | |
Rep 3,953
Maybe, as suggested before, a light scuff of that area, as perfect as possible, would allow zero reflective qualities to come through once it's matte-filmed, but I'm not the half-ass sort, I'm the whole-ass sort, so I'd have it refinished properly before filming. |
03-12-2024, 01:44 PM | #20 |
Be Present
324
Rep 84
If efficient, reliable, and inexpensive is “half-assed,” I guess I’m the half-assed sort then.
Shops have an extremely difficult time with frozen coatings. They’re way more likely to get it wrong than a simple wrap. OE finish > respray |
03-12-2024, 01:56 PM | #21 | |
Rep 3,953
It's not a respray as long as you don't break through the top coat. All that's needed is a scuff of the clear, and re-clear. It's not that hard, and quite inexpensive. The only issue is the fact that the clear can't be "worked" afterwards, so it has to be done in the best possible environment. |
Tags |
frozen grey, matte |
