      03-20-2024, 04:11 PM   #1
Namelss
Namelss's Avatar
Drives: 2007 Volvo XC90 V8 Sport
Scratched interior trim
I put a verrry light scratch in the "carbon look" metal trim at the top of my drivers door. I stuck my hand out to push the door back open and hit it with the watch that I never wear.
Any suggestions on what I can use to buff this out without making it worse? It's barely noticeable but I know it's there. Thx!
2022 M5C Snapper Rocks Blue Metallic ~Tartufo
      03-20-2024, 04:27 PM   #2
tracer bullet
tracer bullet's Avatar
Is it a textured surface, or smooth? If it's textured, you probably can't do anything. If it's smooth, for example has like a clear coat on it, then you might be able to remove it with paint correction methods (a little polishing compound for example).
      03-22-2024, 01:36 PM   #3
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.70]
Try adding some wax and see if it will fill it/blend it.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      03-22-2024, 04:12 PM   #4
cbpip
cbpip's Avatar
400
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [10.00]
Cross grain, not likely.
      03-22-2024, 08:25 PM   #5
John in VA
Drives: 2015 228i M Sport
Mask off the entire trim piece and spray it with a light coat of satin or matte black trim paint.
      03-23-2024, 06:47 AM   #6
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
I would NOT use any abrasive compounds/liquids on that. But I would try to lightly buff it with a slick detail spray and microfiber towel to gently knock down the scratch. Go easy, take your time and eventually work the entire area so as to blend in the appearance...
      03-25-2024, 10:25 AM   #7
S EyeLand
Drives: F90 M5C
the interior trim stinks in the M5, mine is scratched as well. I ordered an overlay that installed in the dash, and it looks great. Deciding on doing the doors in alcantara or CF. Waiting for a sample from the manufacturer.
      03-28-2024, 08:46 AM   #8
MADBMWX5MC
MADBMWX5MC's Avatar
Drives: 2023 BMW X5MC
OP what did you end up doing?
