      04-27-2024, 07:01 AM   #1
Petroleum
Drives: German
should I get panoramic sunroof tinted? The glass is dark but doesn't block any heat.
should I get panoramic sunroof tinted? The glass is dark but doesn't block any heat.(with the sunshade opened) Is the factory glass only dark in color and doesn't filter any heat from the sunlight? when I drive, I can feel the heat on my head now that weather is getting warm.
the car is a '23 X1. The panoramic glass panels are all dark glass and only the glass panel above the front passengers can slide back.
      04-27-2024, 01:18 PM   #2
John in VA
Drives: 2015 228i M Sport
Go for it! There are some newer ceramic films that block heat without being too much darker. The factory tint does block some IR. Keeps parasites out, too!
I have LLumar FormulaOne Pinnacle Ceramic Tint on my cars, legal for VA. The LLumar IRX heat-rejecting window tint features advanced nano-ceramic construction that specifically targets infrared rays. This is what gives LLumar IRX tint its name and its cooling power.
      04-27-2024, 05:07 PM   #3
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
I was going to recommend Llumar IRX 50% on it... good stuff.
But be prepared... quote for a panoramic sunroof is about $400.
      04-27-2024, 08:13 PM   #4
Fredcohiba
Drives: 2022 X3 xDrive30i
Heard some rumblings that if you tint, any issues with the sunroof will be denied under warranty.
icj_45e156.50
Rocket455543.50
      04-27-2024, 11:20 PM   #5
25X740i
Member
25X740i's Avatar
Drives: 2025 BMW X7 40i
I’ve been doing some research about doing mine. Haven’t found any verifiable warranty denials, but have found several recommendations not to go any darker than 70% to keep from reflecting too much heat back into the glass. Apparently that is what causes any issues. I’ve decided to go with Llumar Air 80. It’s a classed as a clear film (slight bluish tint on clear glass, but supposedly unnoticeable on factory tinted glass). It is supposed to block approximately 46% of the heat. Blocks 60% of IR light and 99% of UV light. I found it recommended by several tint shops online, and it’s the only film my local shop recommends for sunroofs. Just my 2cents.
https://llumar.com/na/en/automotive/window-tint/clear/
      04-27-2024, 11:30 PM   #6
Pheonix
2007 BMW/Z4MC  [0.00]
This is a potential issue for sure!
I have 3M Crystalline on my DD (VW id4). However the install wouldn't install it (or any ceramic tint) on the roof because they said the tint manufacturer won't allow due to ceramic tint traps heat and would potentially cause crack on the glass roof.
      04-28-2024, 01:42 PM   #7
DocL
DocL's Avatar
Drives: 2018 M3 Comp 6spd
Ive tinted 25 cars over the past 20 years, and everytime I asked to tint the sunroof glass I was told they wont do it. I even begged and said I'll pay anything, and I was still denied.
      04-29-2024, 03:17 PM   #8
ipilcher
ipilcher's Avatar
665
Drives: 2024 M3 Compensation
Would a windshield film, which goes on the outside, work?
BSfmAZ364.50
      04-30-2024, 10:29 AM   #9
celsdogg
E4 Mafia
356
Drives: E30, E36/5, E46x2, F22, F30
What parasites do we mean here?
Squad - '90 E30 325i MT (226k) | '98 E36/5 318ti MT (160k) | '03 E46 325i MT (156k) | '04 E46 330xi MT (195k) | '15 F22 M235i MT (66k) | '15 F30 335i MT (85k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k)
Bring back the purple M stripe
      04-30-2024, 12:17 PM   #10
John in VA
Auto-correct had parasites instead of panoramic initially - I couldn't resist!
      04-30-2024, 12:27 PM   #11
celsdogg
E4 Mafia
356
      05-03-2024, 02:10 PM   #12
Petroleum
Drives: German
it was actually "parasitic sunroom" thanks to auto-correct. I didn't realize it until much later.
as for the actual tint for the panoramic sunroof, I'm putting that idea on hold.
After visiting two different tint shops(one xpel and one 3M), they both wanted me to sign waivers for tinting the panoramic sunroof glass. Sounds too ominous to me.
      05-03-2024, 03:28 PM   #13
MADBMWX5MC
MADBMWX5MC's Avatar
Drives: 2023 BMW X5MC
Gotta admit, never heard of this being done until I read it here...
      05-04-2024, 02:38 PM   #14
25X740i
Member
25X740i's Avatar
I was skeptical at first, did a lot of reading on line. I found about 50-50 for and against from "Installers". I found lots of horror stories about the glass shattering, but none that were first person. In other words, lots of "I knew this guy once..." type stories of it happening. Here's my thoughts... The sunroof is made of glass just like the windshield and side windows and rear hatch windows. No one has any problem tinting those with ceramic film. they are all exposed to the same sun and same temperature for the same amount of time. As a dealership service manager in my younger years, (granted it was before ceramic film became widely available) I personally have never seen one break from heat. I may end up with a big out of pocket expense for a new sunroof, but then I'll know. I'll update this with the results. With all the complaints about the A/C system on the X-7 and Texas heat, I'm going to take the gamble.
BSfmAZ364.50
      05-04-2024, 02:50 PM   #15
cooolone2
cooolone2's Avatar
723
Drives: 20' M240iX B58, 01' 330XI E46
Well... I call fake news on the "being denied" thing in regard to any issue with a sunroof and tint being present! The Magnuson-Moss Warranty act took care of this back in 75' folks... In order for any warranty to be denied, the insurer would have to demonstrate that the Tint on the glass led to the failure! An extremely difficult thing to do! This all goes to a dozen or so different scenarios where unscrupulous dealers and whatnot looked to deny deny deny taking care of something they're responsible for. For example, an after market exhaust on a car denying warranty on a spun rod/blown engine! Installing an aftermarket audio system and having an electrical failure with the headlights... Blah blah blah...
Sorry, but no! I would love a dealer to tell me the sunroof motor stopped working because I tinted the glass! After I stopped crying from laughing so hard, I would be on the phone direct with corporate and public relations as a stock holder making complaints! You'd be surprised how quickly things get resolved. Anyways...
Tint, use ceramic tint and don't look back. Enjoy!
      05-07-2024, 10:30 PM   #16
BSfmAZ
BSfmAZ's Avatar
Drives: '24 X5 M60i,'23 Z4 30i, CLS 63
2024 BMW X5 M60i  [9.50]
2020 miata mx5  [10.00]
2023 Z4 30i  [9.50]
Had a 2012 MB 350 with a full sunroof in Tucson AZ. Had the roof done with ceramic tint, kept the car 3 years no problems. Granted it was garaged when not on the road, but it did get plenty of vitamin D. Currently have a 24 m60i and waiting for full summertime 117 temps. I may consider tinting...
      05-08-2024, 10:48 PM   #17
BSfmAZ
BSfmAZ's Avatar
2023 Z4 30i  [9.50]
So u r giving up on tinting the sunroof?
      05-11-2024, 06:42 PM   #18
Petroleum
Drives: German
went to two more tint shops a little farther away this morning. both also recommended against tinting the panoramic sunroof.
so, yes, I'm officially giving up on the idea.
      05-12-2024, 04:29 AM   #19
MADBMWX5MC
MADBMWX5MC's Avatar
Curious as to why they recommended no tint?
      05-12-2024, 12:11 PM   #20
Petroleum
Drives: German
all said the excessive heat in my area as the main reason... apparently sunroof glass(regular size or panoramic) absorb heat and can crack. They all said that they would NOT be responsible if the glass breaks after tint installation
my guess is that they have seen too many cases.... (mostly Tesla, Honda, Audi... according to them)
      05-12-2024, 03:26 PM   #21
MADBMWX5MC
MADBMWX5MC's Avatar
Dang, interesting.
      05-12-2024, 04:58 PM   #22
335i54n
Drives: e90 335i, e39 m5
interesting, I had my E39 sunroof (sits outside) and relative Acura TSX tinted forever. Maybe glass is more brittle and it's a hot roof, cold water or auto car wash thing.
