      06-22-2024, 07:46 AM   #1
drcop
Drives: M4 Comp
Leather seat wear and tear
I had posted this yesterday accidentally in the Cosmetics forum however I'll try here:
I am starting to get the wear & tear (cracking and fading) on my Fiona red seats. Can anyone advise what is the best fix for this before it gets worse—repairs and perhaps preventative measures?
      06-22-2024, 08:39 AM   #2
BigHunk
///M
BigHunk's Avatar
Drives: X5M , iX , S1000XR
Swissvax would be your choice, leather requires conditioning at least once a year otherwise you'll get issues like seen on your car.
Here is nice tutorial how to do it and results after treatment, also they have online shop, Canadian store based on your location.
not rich enough to buy cheap
Hagasan41360.50
miser81.00
      06-22-2024, 09:11 AM   #3
John in VA
Drives: 2015 228i M Sport
Moving the seat back to get in/out of the car will help decrease bolster wear. It will require some color/dye at some point.
ppointer1183.50
DocL2226.50
      06-22-2024, 11:28 AM   #4
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
2009 528i  [8.60]
2022 BMW 540i  [0.75]
2008 Infiniti QX56  [5.00]
1967 Chevrolet Corv ...  [10.00]
2012 BMW 335i  [8.29]
2001 M Roadster  [10.00]
2012 BMW 335is  [7.93]
2013 BMW M3 Vert  [9.67]
+1 for John in VA to prevent further damage. I have my #2 seat position set for several inches back. I get in the car at the #2 memory position, and hit #1 to move it forward. This has stopped any new damage to my seats.
      06-22-2024, 12:57 PM   #5
jkoral
Drives: 2017 M2 LBB 6MT
All modern BMWs have EasyEntry built in so it does it automatically, but it has to be coded on. I enabled it with BimmerCode on my 2017 M2. Lots of threads on bimmerpost, first one that popped up: https://f80.bimmerpost.com/forums/sh....php?t=1827447
visionaut1569.50
      06-22-2024, 01:35 PM   #6
Hagasan41
Hagasan41's Avatar
Drives: 2013 E92 ///M3, 1999 E36 ///M3
Swissvax makes some really great products. My go to is their leather cleaner in the video posted above. Colourlock is another great brand I use. Clean and condition especially on the high wear areas needs to become part of your detailing routine.
My seats still look brand new.
https://www.colourlock.com/BMW-Leath...008-us-BM-284/
Below are some steps you can take to repair and prevent in the future…
-Use the Colourlock dye to repair
-Apply Colourlock leather shield to help protect
-Change the way you’re getting in and out of the car. Instead of kinda rolling into and out of the seat you’ll need to use your hand on the door sill to kinda lift yourself into and out of the seat. Or as mentioned above utilize the M1 and M2 features.
2013 E92 M3 |Space Grey | Fox Red | Manual
1999 E36 M3 |Hellrot Red | Black | Manual
IG: @moya_M3
      06-22-2024, 07:12 PM   #7
BMWCCA1
BMW Owner Since 1971
2683
2013 BMW 128i  [10.00]
A customer who was a physical therapist taught me this trick back around 1995, mostly to prevent back issues as we age but it also works for not chewing up your seat bolster:
Stand with your door open with your back to the car. Put your ass in the driver's seat while both feet remain planted on the ground. Swing your feet around into the pedal box. Voila! No seat damage. The sport seat on my 2013 128i still has a perfect bolster after over 100k-miles.
a5m1212.00
Wolf 3352573.00
DocL2226.50
tcphoto4791.50
      06-22-2024, 09:04 PM   #8
jg4c
jg4c's Avatar
475
Drives: 2022 M340i XDrive
Stand with your door open with your back to the car. Put your ass in the driver's seat while both feet remain planted on the ground. Swing you feet around into the pedal box. Voila! Do seat damage. The sport seat on my 2013 128i still has a perfect bolster after over 100k-miles.
Exactly what I adopted doing after seeing some wear
in the exact same spot on the bolster that OP posted.
Started only after 6 months on my brand new 2022 M340
with Vernasca leather. Aggressively treated the spot with
leather conditioner. That combined with new way to enter
the car and problem solved.
      06-23-2024, 08:34 AM   #9
BMWCCA1
2683
Thanks for making me see my typos (now corrected) and for confirming what should be obvious to everyone with sport seats by now!
      06-23-2024, 08:50 AM   #10
bosstones
Drives: o_0
I've always put my right leg in first then used that method. I find it helps distribute weight while I get in, especially if there is not room to open the door much. Getting out, I post my left hand on the bottom trim above the sill.
      06-23-2024, 09:09 AM   #11
cbpip
cbpip's Avatar
400
Drives: BMW Z4C 3.0si 3 pedal
2007 BMW E86C  [10.00]
Leatherique is a great reconditioning treatment for leather. No petroleum products which will deteriorate leather and stitching. Uses emollients for softening and recognitioning the leather.
ayilar173.00
M5Rick79703.50
tcphoto4791.50
      06-23-2024, 10:59 AM   #12
Portimao Blue M440ix
Portimao Blue M440ix's Avatar
271
Drives: Bmw m440ix g22
I find for myself being conscious of the bolster getting in and out helps. I use my forearm against the upper portion of the backrest area getting in and out to keep the rest of me rubbing against the bolster. My 2007 335i coupe bolster still looks brand new.
      06-25-2024, 10:47 AM   #13
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.70]
Why not just code easy entry? As soon as the car powers off the seat automatically pulls back. When enter and then close the door, the seat automatically moves back forward.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      06-25-2024, 12:18 PM   #14
BMWCCA1
2683
That's exactly what my customer the physical therapist was warning against. How's your back?
      06-25-2024, 03:09 PM   #15
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.70]
Originally Posted by M2siast View Post
How do you do that?
Bimmercode.
N1rve
      06-25-2024, 08:20 PM   #16
ppointer
2009 528i  [8.60]
Yes, tried that. Doesn't work for either of my 2012 e92s or 2022 G30.
      06-25-2024, 08:48 PM   #17
louielouie
Drives: '18 F80
Get the repair kit from Colourlock.
I used to have that seat movement thing. Turned it back off. Personally, I found it annoying
M5Rick79703.50
      06-26-2024, 06:44 AM   #18
MADBMWX5MC
MADBMWX5MC's Avatar
Drives: 2023 BMW X5MC
I was wondering about that, thanks for the post
      06-26-2024, 07:54 AM   #19
DocL
DocL's Avatar
Drives: 2018 M3 Comp 6spd
And not wearing jeans helps too.
      06-26-2024, 07:02 PM   #20
bosstones
Drives: o_0
Doing great!
      06-01-2025, 11:35 PM   #21
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
371
Drives: 2018 BMW M2 LCI
How is everyone finding this product, Leatherique Rejuvenator?
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
      06-02-2025, 09:01 AM   #22
UPSROD
Drives: 2013 E92 M3
2013 BMW M3  [10.00]
I just use the backrest button to move the seat back and when I start the car the seat returns to the correct position!
