06-27-2024, 04:40 PM | #1 |
![]() 31
Rep 90
Ryobi 1800 psi 1.2 gpm pressure washer question
Just wondering which nozzle/orifice size they used to get the 1800 psi claim?
From my experience,the higher the larger orifice size equals less pressure.H50 |
06-28-2024, 09:09 AM | #3 |
![]() 432
Rep 1,036
Probably won't get anywhere near 1,800 psi regardless of nozzle/orifice. Plus you don't need that much pressure for car washing.
What important are the good/high flow, orifice spray angle (40 degrees is highly recommended). |
Huck5030.50 |
06-28-2024, 02:48 PM | #5 |
![]() 31
Rep 90
I like to use the RED 00040(.156) nozzle for the driveway wash and I just ordered a 00045 (.164),will I still get a good pressure with the new 45 nozzle?
My Ryobi came with an orange 00030(.141) and rotating nozzleThanks,H50 |
06-28-2024, 03:23 PM | #6 |
![]() ![]() 835
Rep 1,281
06-28-2024, 04:06 PM | #7 |
![]() ![]() ![]() 435
Rep 502
I'm pretty sure (based on my amazon order history) that it's a 4.5, they have nozzles up to 6.0 on amazon.
2022 BMW M550 Xdrive (stock).
06-28-2024, 04:20 PM | #8 |
![]() 432
Rep 1,036
I believe Obsessed Garage did an extensive project and tested most common PW. Do a search for Obsessed Garage "Watch the Pressure Washer Tests" and I am pretty sure he gave recommendations for Nozzle size.
06-28-2024, 04:56 PM | #9 |
![]() ![]() 835
Rep 1,281
As Phoenix mentioned, you should refer to the chart and get a new orifice then. You're running one way too large for your machine. I would guess it should be around 2.5 and not 4.5.
06-28-2024, 06:17 PM | #10 |
YNWA
![]() 1354
Rep 1,066
I went with a westinghouse pressure washer because the GPM was the highest of any cheap washer (1.76 - most are 1-1.2). I wouldn't worry about pressure, but I would reduce the orifice size (to 1.1 - usually they come with 1.25) for the foam cannon that you use. That's where you do want more pressure to get good foam. For rinsing, you want higher flow, not pressure.
For the 25/40 spray tips, I went with orifice 2.5 because it matched with my specs (1.76 gpm, 2100psi) based on hydro mtm's calculator website. But I'm thinking I will try 3.0 to reduce pressure further. However, I don't mind slightly lower flow when rinsing the car off as it should increase the effectiveness and extend the life of my DI resin :P
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
06-28-2024, 06:46 PM | #11 |
Rep 502
According to my calculations, my setup would yield me a pressure of 280psi with a GPM of 3.02.
Is that GPM even possible for the ryobi’s rated 1.2? Oh well, been using this setup for a while now and it works pretty well. |
06-28-2024, 07:06 PM | #13 | |
![]() ![]() 835
Rep 1,281
Huck - as much I don't like OG's channel, he has a posted spreadsheet with orifice sizes based on actual testing. Looks like you should be using a 1.7 orifice for 1K PSI and 1.4GPM. Do not waste your time with 4.0 etc |
Huck5030.50 |
06-28-2024, 09:15 PM | #14 | |
![]() 31
Rep 90
06-29-2024, 11:07 AM | #15 |
Rep 24
I really don’t like rinsing with a pressure washer. The flow just isn’t high enough unless you have a really big pressure washer. Get a nozzle from Eley Hose. The shower nozzle provides a very laminar, high flow rinse stream. Their products are built very well from heavy bronze and stainless components. They are serviceable as well. I use a pressure washer to pre rinse and foam but switch to the hose and Eley nozzle for rinse.
06-30-2024, 10:59 PM | #16 | |
Rep 502
saw a video on this nozzle and i'm sold, another tool I am going to buy ![]()
07-01-2024, 03:13 PM | #17 | |
![]() 31
Rep 90
