07-14-2024, 09:59 AM | #1 |
![]() 96
Rep 75
Wheel barrel brush
Can anyone recommend a wheel barrel brush that fits between the barrel and the calliper on a M4 Comp on 20’ rims.I have a full set of Wheel Woolies and use the medium 1 but this won’t fit between the calliper.
Looking for something a bit flatter. |
07-14-2024, 10:41 AM | #3 |
![]() 96
Rep 75
07-14-2024, 11:47 AM | #4 |
![]() ![]() ![]() ![]() 340
Rep 529
Drives: 2021 M340i xDrive
P&S Brake Buster is great on wheel dust, and you can dilute it around 5:1 to make it last longer (not required, you can use it straight from the bottle or container). Use a thin microfiber-sleeved brush, like this one: https://www.amazon.com/dp/B0BHXCF44B/
07-15-2024, 05:17 AM | #5 | |
![]() ![]() ![]() 474
Rep 396
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1 |
Clarkie5295.50 |
07-16-2024, 01:32 PM | #6 |
![]() ![]() 1631
Rep 4,108
I have been using this one since my 2010 M3. Works great. Fits between the wheel and the 6 piston calipers on my X5M.
https://www.amazon.com/Speed-Master-..._source=1&th=1 |
07-16-2024, 01:35 PM | #7 | |
![]() 96
Rep 75
07-16-2024, 04:04 PM | #8 | |
![]() ![]() ![]() 5000
Rep 5,074
For my Z4, but it is indeed thin and might be a candidate here. Comes with a few extra "sleeves" as well. |
07-17-2024, 02:29 PM | #10 |
![]() 1414
Rep 2,575
I wear a black T-shirt when I'm using my large or small SpeedMaster brushes! The Wheel Woolies-type do a good job as well. Sometimes it's worth it to just remove the wheel & tire from the car for cleaning.
21X3M40116.50 |
07-28-2024, 09:18 AM | #11 |
![]() 9092
Rep 2,702
What size brush is needed if the wheel is taken off the car to clean the barrel?
07-28-2024, 10:56 AM | #12 |
![]() ![]() ![]() ![]() 2058
Rep 638
I'm with you on that! All kinds of nastiness sprays back at you, including the chemicals that you are using.
07-28-2024, 12:04 PM | #13 |
![]() 1414
Rep 2,575
Just about any size works to clean the barrel with the wheel off the car. You still need a brush small/flexible enough to hit the edges of the holes & spokes.
07-29-2024, 02:20 PM | #14 |
![]() ![]() ![]() ![]() 640
Rep 736
I use these for my car. I have the M Sport brakes, so 374mm front rotors and 4 piston calipers. They fit.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
08-31-2024, 04:06 PM | #15 |
![]() ![]() 288
Rep 169
Drives: 2025 M4 Competition
Greetings,
Or...you can make your own... Semper Fi |
09-01-2024, 07:07 AM | #16 |
![]() ![]() ![]() ![]() 2471
Rep 950
I use this small brush from Adams to get between the caliper and the barrel. Unfortunately, it's sold out now.
https://adamspolishes.com/products/a...ni-turbo-stick For the rest of the barrel, I use a Woolly Wormit. It works really well but doesn't fit between the caliper and barrel on my 20" wheels. https://www.amazon.com/Detailing-Int...e%2C105&sr=1-2 Last edited by cb804; 09-01-2024 at 07:13 AM.. |
