10-06-2024, 06:32 PM | #1 |
![]() ![]() ![]() ![]() 2058
Rep 638
Native Floridians - your take on Milton?
My son lives in a new townhome on Tampa area - built to modern codes and hurricane standards.
We decided that he should install his shutters, turn off breakers to bottom level (garage, storage and foyer), and spend a couple nights in Orlando, just to be safe and not have the car flooded or be trapped by water. Given everything about the storm's path, how might Orlando area be impacted? Asking because his mother is cranking up the anxiety machine and has him spooked about his plan. My guess is that worse case scenario is that his hotel loses power for a bit. At this point, it looks like the storm will travel well South of Orlando.
10-06-2024, 07:21 PM | #2 |
![]() ![]() 10310
Rep 4,151
Can’t speak to your Florida specific questions but your advice on shutters, electric, heading to Orlando are spot on. Having lived in New Orleans most of my life including Katrina, you don’t mess around with these storms. IMO if he could head even further north, I would do that. Keep the gas tank full, totally empty the refrigerator/get rid of any perishables, bring any important papers/photos with him. Nothing worse than coming home to a fridge ruined by spoiled food…
2025 Lexus GX 550 Overtrail
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 ![]() |
10-06-2024, 07:54 PM | #3 |
Rep 11
Native here. Depending on the strength of the storm, power may be lost in Orlando. He would certainly be better off than Tampa.
10-06-2024, 08:25 PM | #4 |
![]() ![]() 12445
Rep 4,905
Advice for Tampa prep and going to Orlando is good. Logically, Orlando will not have nearly the same impact as coastal areas because there is no storm surge in Orlando. Maybe power outage which can also lead to cell service being down. In general, get away from the coast when a storm is coming and Orlando is a good spot.
Also, kscarrol made some good suggestions and to those I would add have cash on hand, keep portable devices charged and have some water, food and snacks (and liquor if so inclined) on hand in Orlando. Before leaving get anything important out of storage on lower level and either bring it or move it to upper level. Tell him to make sure he calls or texts you as soon as he can once the storm passes. (Don’t panic if you can’t reach him during or right after storm.)
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
DrVenture2057.50 |
10-06-2024, 08:32 PM | #5 |
![]() ![]() ![]() ![]() 4060
Rep 10,703
I would go north of Tampa. Generally you want the storm to move parallel and on the backside of the rotation.
So if it's moving W-E then be on the North side. If it's moving S-N then be on the West side. Maybe head to Gainesville or Tallahassee.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line Last edited by F32Fleet; 10-06-2024 at 08:33 PM.. |
10-06-2024, 08:36 PM | #6 |
Rep 638
Thanks. Great advice. Much appreciated. Have done pretty much all of that. Except empty fridge. Will talk to him in the a.m. about that too.
Nothing of value on lower level, Just a few odds and ends on a shelving unit in storage. Nothing on floors. Our expectation is that Orlando could lose power, but should be safe. Already booked the room. Advised him to fill up as he enters Orlando area. Should only need about 2-3 gallons after traveling. He has multiple power bricks and batteries all charged. He has cash (and full tank of gas) and will get more cash tomorrow. Shutters going up at 8:00 am - confirmed. Plans to bring water and dried snacks with him. Fortunately his electric is below ground and he is on same grid as nearby hospital. Hoping that helps.
RickFLM412445.00 |
10-06-2024, 08:42 PM | #7 | |
Rep 638
Thank you. Good luck to everyone. After Helene, no doubt everyone is on edge.
10-06-2024, 08:45 PM | #8 | |
![]() ![]() 12445
Rep 4,905
Has he ever put shutters up before? If they are the heavy galvanized steel shutters, it is not a fun project (nor is taking them down). Presumably he’s young, which is good. If he can get some help with those or hire someone to do it, I recommend doing so, especially since he has a townhouse and presumably needs to get on a ladder to put them on a second floor. (We had them before we invested in impact resistant glass and put them up several times on a single story house.) Also one more thing: obviously, bring anything outside (grill, furniture, etc.) into the garage.
DrVenture2057.50 |
10-06-2024, 08:56 PM | #9 |
Rep 638
Outside is clear, including screen porch. He has a guy lined up to do shutters, and the guy left his ladder in son's garage saying he'll be back first thing in morning. Also, he has a second guy who told him to call if the first guy falls through. Also, counted the shutters and located the hardware.
We spent all day planning and working out details. I even walked him through disconnecting the garage door sensors from the brackets and hanging them well above ground. Otherwise they will be under water with just a few inches of intrusion. A small detail, but nonetheless. Thanks again. Really appreciated.
mjj1059.50 |
10-06-2024, 09:00 PM | #10 |
![]() ![]() 12445
Rep 4,905
Sounds like you have it all planned out better than many Floridians. Good luck to you son.
DrVenture2057.50 floridaorange14233.00 |
10-06-2024, 10:04 PM | #12 |
![]() ![]() 1184
Rep 1,302
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2009 528i [8.60]
2022 BMW 540i [0.75] 2008 Infiniti QX56 [5.00] 1967 Chevrolet Corv ... [10.00] 2012 BMW 335i [8.29] 2001 M Roadster [10.00] 2012 BMW 335is [7.93] 2013 BMW M3 Vert [9.67] |
Our winter home is half an hour north of Fort Lauderdale, 12 miles inland and up against the Everglades. This will probably be a cat 4, and no guarantee which direction it goes, but seems to be headed to Sarasota at the moment. If we were there now, we would be flying out tomorrow morning. Really only willing to sit out cat 2 or less, and we have hurricane windows. If the storm is 3 or stronger, we leave. Milton is currently forecast to be a cat 1 when it reaches Jacksonville, for pete's sake, so who knows how strong it will be when it reaches Orlando. Also, there has been so much rain down there lately, this will certainly be another flood event. Glad my flood insurance is current.
DrVenture2057.50 |
10-07-2024, 06:45 AM | #13 | |
![]() ![]() 12445
Rep 4,905
The west coast of FL should clearly be concerned about storm surge and inland areas will be getting lots of rain. Evacuating the coast is the right thing to do but you don’t necessarily need to evacuate hundreds of miles. Our summer place is in Asheville, and we have planned to go there if a bad storm caused extended power outages in Wellington. Fortunately we weren’t there for Helene (our place there is fine, but city is a disaster). This is a good app for tracking storms: https://apps.apple.com/us/app/hurric...ad/id369266386
10-07-2024, 07:12 AM | #14 |
![]() 4260
Rep 1,019
Also turn off water at street or entry to his unit. And natural gas at the meter.
Not native to FL, been through a lot of storms however. I’d go north, but parts of GA still a mess from Helene so NW might be a better direction. More likely to maintain communications, get gas and food for a potential extended stay. |
10-07-2024, 07:15 AM | #15 | |
![]() ![]() ![]() 1060
Rep 489
Do you believe the housing values will drop dramatically in the same areas (FL coastal) that have had massive increases over the past6-8 years? Hoping I am way off on my prediction. |
10-07-2024, 07:15 AM | #16 |
![]() ![]() 10310
Rep 4,151
On a tangent from the water comment above, when emptying the refrigerator, don’t forget the freezer. Dump the ice, turn off the ice maker etc or it will melt, potentially causing water damage or just leaving the freezer a mold/mildew disaster after an extended power outage.
10-07-2024, 07:36 AM | #17 |
![]() ![]() 11706
Rep 9,471
Lifelong native here... I've been in a house that was in a no flood zone in Cat 2 -3 winds... 115-120 MPH... would never do that again. Nothing ended up happening but it felt like the house would fly away at times... if you are closer to water or at any risk of flooding in the path, you need to get out of the way asap.
10-07-2024, 07:42 AM | #18 | |
![]() ![]() 12445
Rep 4,905
I do not foresee house prices dropping because of storms or P&C. People still move here in droves and they need housing. Condo prices will be under pressure because of state laws to complete mandatory repairs and fund reserve accounts, which triggered assessments and higher dues. In Asheville, very few people have flood insurance, which is inconceivable to me for anyone living near the rivers. That is going to be a mess to sort out. On one hand people are in dire straits. On the other, if they can rebuild with government money, why should anyone buy flood insurance if there is a safety net without it?
mjj1059.50 |
10-07-2024, 08:44 AM | #19 | |
![]() ![]() 1184
Rep 1,302
Milton has already intensified to cat 4. Good thing we're up in Ohio |
10-07-2024, 09:55 AM | #22 |
![]() ![]() ![]() ![]() ![]() 2227
Rep 990
I'd follow the suggestions of Gov. DeSantis and the NOAA tracking forcast. It'll probably be better to travel to Miami/Broward/Palm Beach than going to Orlando.
"Education will never be as expensive as ignorance." |
DrVenture2057.50 |
