01-08-2025, 10:51 PM | #1 |
![]() 54
Rep 213
Wheel Cleaner with CCB
This my first set of CCBs, and my wheels are ceramic coated. What are you guys using as a wheel cleaning spray when there’s low dust and no iron contamination? I assume I want to stay away from any cleaner that is meant for steel brakes since they’ll like contain caustic compounds for iron dust. PH neutral is a must I guess. Any suggestions appreciated.
2025 G80 M3 6MT / Imola Red II / Silverstone / Carbon Buckets / Carbon Exterior Package / CCB / HKStudie Exhaust
1999 E36 M3 / Titanium Silver / Black Vaders / Supersprint / Jim Conforti Tune / Fikse FM10 / Single Owner |
01-09-2025, 10:41 AM | #2 |
![]() 519
Rep 1,315
Leftover car wash shampoo ......
If you have a Pressure Washer, it's really just the surface film that is needed on a mechanical wash post HP rinse Be mindful when you dress the rubbers Last edited by chefwong; 01-09-2025 at 10:56 AM.. |
01-23-2025, 11:15 PM | #3 |
![]() 3162
Rep 2,557
Drives: INDIVIDUAL F90 M5C LCI
I use Gtechnique "Iron fallout remover" and the "Citrus foam soap" in a completely differely bucket and brushes
NOW: '21 M5|FSHNGRY|TARTUFO|CCB| MPE|KW|IND|EVENTURI|EISENMANN|DINAN|BBS|
GONE: '15 F82 M4|YMB| IND|MPE|KW|BM3| GONE: '11 E92 335iS|BLKSPHR|OYSTER| GONE: '05 E46 ZHP|DINAN STG3 PKG| https://www.youtube.com/channel/UCva...WCpLE9CH6t9Jeg |
01-24-2025, 06:45 AM | #4 | |
Rep 624
The reason is because the carbon core of the disc oxidizes when exposed to oxygen (or temps over 600°F), which causes the disc to degrade. If you look closely at the edges and vanes of the disc you'll see a grey metallic coating, and it's this coating that keeps oxygen (air) from getting to the disc. On the face of the disc you'll see the tell-tale cracks, and wear indicator circles. Inside these cracks and circles is this same metallic coating, protecting the disc from oxidization. Using products with various chemicals in them can degrade this protective layer over time and cause the disc to lose integrity. I'm a CCB guy, so if you have any other questions, feel free to DM me. |
IL8Apex54.00 |
06-29-2025, 08:49 AM | #5 |
![]() 164
Rep 258
I used Mequires hot wheel cleaner for gloss black wheels yesterday. I let it sit for a couple minutes and then rinsed with a pressure washer. When I went to pull the car in the garage it felt like less bite in the brakes. Did I ruin my ccb??
2026 M4 Miami Blue | Build Journal
[/URL] https://g80.bimmerpost.com/forums/sh...0#post32111100 2024 X5 40i Skyscraper Gray (Wife's car) |
06-29-2025, 09:10 AM | #6 |
Rep 624
Ph level is 8 so you didn't damage anything with it for sure. Most likely what happened is that the rotors were still wet when you pulled it in (if not on the front side then the back side), and CCB's don't work well when wet.
06-29-2025, 09:28 AM | #7 |
![]() 164
Rep 258
The car was in the garage all day not driven. I backed it out and washed it in the shade so there was zero heat in the brakes or wheels. I started pulling forward and almost hit my garage wall because it felt like it wouldn't stop.
I understand ccb doesn't bite as quick when wet and cold so I hope that is all it was.
06-29-2025, 09:30 AM | #8 |
![]() 164
Rep 258
Mequires data sheel says the ph level is 13.56 whatever that means.
https://www.meguiars.com/sites/defau.../G95%20SDS.pdf
06-29-2025, 09:57 AM | #9 |
![]() 1489
Rep 1,143
pressure washer, dawn detergent [Ph ~8-9] but only way the really get the wheels clean is hands on, [not necessarily these but something like them]
https://www.amazon.com/BokWin-5-Fing...ef=sr_1_7?th=1
Two is One and One is None
07-07-2025, 03:38 PM | #10 |
![]() ![]() 84
Rep 162
You're probably looking for this. P&S Brake Buster. PH Neutral, does a great job and ANY brakes in your fleet, and actually does a pretty good job of cleaning regular debris off you tires too.
https://psdetailproducts.com/product...oEnaWc-qa24SgI |
07-07-2025, 05:24 PM | #11 | |
![]() ![]() ![]() 307
Rep 443
2025 MB CLE53 AMG
2023 M340i X drive (Mineral White Metallic, Oyster Vernasca Leather, DAPP, Shadowline, PAP, Premium, Cooling & High Perf Tire, Adap M Susp, HK, Drive Recorder, Sensatec Dash) |
