      01-31-2025, 08:01 PM   #1
amin2020
Drives: M3 Comp
Scuffs on car, recommendations on fixing?
Not sure how this happened but it bugs me every time I look at it. Shows up under the light. Any recommendations on fixing? TIA
Jbucks42.00
      01-31-2025, 08:59 PM   #2
Mech Spec
Mech Spec's Avatar
Drives: '25 M240xi
Need to be polished out, I'd ask a detailer to do it unless you fancy buying a DA and polish and learning on your nice car.
2025 M240i Xdrive TNM
~~Build Thread~~
nazali1514.50
      01-31-2025, 09:16 PM   #3
amin2020
Drives: M3 Comp
Thank you
      01-31-2025, 09:54 PM   #4
V1_ROT8
Drives: 2018 340i xDrive 6MT
Hard to tell because of the color, but those don’t look too deep into the clear coat. You should be able to get those out with some hand polish or rubbing compound if you don’t have a random orbital/DA polisher.
m3628.50
      01-31-2025, 10:35 PM   #5
nazali
nazali's Avatar
Drives: 230 2020 vert F23
a good detailer can get a lot of stuff out, search for @well somone scratched up my car@ thread and the result... mine was 1000 times worse damage than yours
      02-01-2025, 12:33 AM   #6
Grease23
Drives: BMW 328i
If I may dare to mention a product so commonplace on this forum -- I've never been let down on things like this by plain 'ol Maguire's Cleaner Wax in the maroon bottle. It has some extremely fine polish in it. So fine it will never damage your paint while capable in a few applications of polishing out minor damage. As a wax it isn't particularly durable, so when you're done so you can put something else over it if you don't garage your car.
      02-01-2025, 07:03 AM   #7
bosstones
Drives: o_0
Is it from something dragging avross or just bad swirls from contact washing/drying of the ? Or one of those mystery things that sometimes happens?
Hard to tell from the pix but it looks like a normal paint correction would take care of it. If more bark than bite, maybe even an aggressive clay bar would do.
      02-01-2025, 07:56 AM   #8
tracer bullet
tracer bullet's Avatar
Get yourself a bottle of this: https://www.meguiars.com/automotive/...07-7-oz-liquid
Find the softest cloth in the house you don't mind dedicating to the job. Put a little of the polish on it and go over the marks with light pressure in circles for a while. You'll get rid of the marks and there's no chance you'll actually harm anything (aside form introducing new scratches if you don't choose a soft cloth).
Follow up with whatever wax or other coating you like to use.
This is easy to DIY.
      02-02-2025, 08:39 PM   #9
amin2020
Drives: M3 Comp
I just bought a DA polisher and plan to use it for paint correction. What type of polisher should I look for, and is a clay bar necessary before using the DA? Would a pre-soak and hand wash be enough? Should I also use an iron remover? I’m looking to maintain my car myself, I’d appreciate your suggestions to any good threads to learn more about the process
      02-02-2025, 09:11 PM   #10
Grease23
Drives: BMW 328i
I'd do it (and do do it) by hand, using a circular motion on a terry cloth pad. That way there is no risk you'll overdo it.
      02-02-2025, 10:34 PM   #11
clutchdj
Drives: a few cars
Use the least abrasive pad, typically a white pad, along with Meguiar's 210 polish set to speed one or two. Be sure to wash the car beforehand; you shouldn't need to clay or use additional products. I have no complaints about my Rupes Bigfoot polisher. However, be cautious, as it is possible to etch the paint/glass with a random orbital polisher.
      02-09-2025, 12:10 AM   #12
amin2020
Drives: M3 Comp
This is the one I bought along with the polisher you reccomended. Is it ok to use?
https://www.harborfreight.com/6-in-u...ack-70845.html
