04-02-2025, 10:44 AM | #1 |
![]() ![]() 6711
Rep 2,222
Drives: Here and There
Garage List LMB BMW E90M Stripper [10.00]
80 Series Toyota La ... [8.33] 200 Series Toyota L ... [10.00] JB BMW E90M Stripper [10.00] 11th Gen Ford F-150 [10.00] |
Headlight Restoration
Hey all. Has anyone here had a professional restore their headlight lenses? I've done it to other vehicles before and they turned out "okay", but I'd like for someone that really knows what they're doing this go round. My E90 M3 has some slight hazing on the upper "brow" of both headlights, so I was hoping for a refresh. You honestly need to get up on the car to really see it, so minor comparative to many others I've seen. I reached out to a local body shop that does this and plan to reach out to some of the detailers in the area as well, but I was really surprised at the cost to get this done. I don't know what I was expecting to see, but ~$700 wasn't the number.
Are they way off mark? Or am I unrealistic in thinking this can be done for much cheaper? For not that much more, I can get a set of upgraded Bayoptiks. Or for even less than this quote I can send them into Bayoptiks and they can replace and ship back with brand new lenses... Last edited by spazzyfry123; 04-02-2025 at 10:54 AM.. |
04-02-2025, 02:15 PM | #2 |
![]() ![]() 4790
Rep 3,442
I refuse to pay that much to have it done, I've tried many "headlight restoration kits" and have had marginal success. The last time I cleaned them up, I used my DA Polisher with a compound followed up with a polish and then a ceramic coating that I used on my new paint and wheels. It's been about eight months and they still look great. It's too bad BMW stopped allowing us to simply swap out the lenses like I did with my old Pre-LCI E46, now it's required to bake the headlight, clean out the black sticky sealant, reseal and then hop on one leg while singing an Octoberfest tone. Don't ask to see a video, it wasn't pretty or entertaining or instructional.
04-02-2025, 07:02 PM | #3 |
![]() ![]() ![]() 198
Rep 566
Don’t pay a professional to do this. The key to lasting results is how you seal the light at the end.
Work your way up wet sanding starting at 600 or 800 and go up to at least 2000 grit. Alternate sanding in different directions with each grit so you can easily tell when you have removed all previous sanding marks. Then polish with your random orbital or polishing pad with drill attachment. After sanding and polishing, you need to either spray clear coat, apply PPF or ceramic coat them. If you spray clear coat, it will probably be multiple coats with some light sanding in between. Those 3 options will prevent the headlights from yellowing or clouding up again due to UV rays. |
s_ribs131.50 StradaRedlands8532.50 |
04-02-2025, 07:43 PM | #4 | |
![]() 3165
Rep 1,923
04-02-2025, 09:06 PM | #5 | |
![]() 135
Rep 101
04-03-2025, 06:30 AM | #6 | |
Rep 624
I always recommend replacing the housing with a used, low-mile OEM unit when you're talking about a $40K+ car. Now if you're driving a $10K Kia... |
04-03-2025, 08:16 AM | #7 |
![]() ![]() 6711
Rep 2,222
Hey, I get it, you guys want to do it yourself. I don’t. I’ve rebuilt engines, set backlash for differentials, changed out clutches… I’ve got no problem rolling up the sleeves for DIY.
But when it comes to detailing, body work, paint… I’m out. It’s just one of those things I just genuinely have no interest in doing. Sure, I like a clean car as much as the next guy, but I’d be grinding my teeth the whole time I’d be doing this. It’s cheaper to ship off my lights to Bayoptiks to change out the lens itself. Will likely have a better result. |
DrFerry8268.00 StradaRedlands8532.50 |
04-03-2025, 08:50 AM | #8 |
![]() 5894
Rep 3,443
I responded to a similar post on the forum. Here's my reply:
https://www.1addicts.com/forums/show...23&postcount=2 The DIY kit I used was cheap and super easy. You may want to consider trying it out. The results were great. Many months later, the lens of my mom's Jeep are still decent but seems to be not as clear as when I first did the job. But frankly I haven't been closely staring at the lenses when I'm around her car. I'll do it next time if I remember to see if and how bad any hazing/dulling there may be. But the members that say to use PPF are spot on. I have PPF on two of my cars. My 1er which is garage kept and sees weekend use and my C-HR that sits outside all the time and is my daily. Both of them are still super clear. I suggest whatever you do to restore the clarity of the headlight lens that you follow up with having PPF put on to prevent any possibility of future hazing again. |
05-07-2025, 07:00 AM | #10 | |
![]() 1413
Rep 2,575
https://www.2addicts.com/forums/show...php?p=31992060
05-07-2025, 07:30 AM | #11 | |
![]() ![]() 6711
Rep 2,222
05-07-2025, 08:01 AM | #12 |
![]() ![]() ![]() ![]() 2305
Rep 751
My F31 was supposed to be used in a photo shoot for RainX back in 2020 and they hired a detailer to refresh the headlights. He said because of the construction of the headlight they couldn't be polished because the deterioration was on the inside of the headlight.
05-07-2025, 09:08 AM | #13 |
![]() 7827
Rep 1,279
I have used a few on my 2004 E85 with ok results. Last summer I used the Cerakote kits and holy moly - they look brand new. I'm fairly picky so even the ones that got it 95% better were just ok - but this one knocked it out of the park. Almost a year later and still looks perfect. Worked for me anyway.
https://www.amazon.com/dp/B084RQKLV8...n_title_1&th=1
05-13-2025, 09:10 PM | #15 |
Rep 5
2007 BMW Z4 3.0i with 100K miles that I recently purchased needed headlight lense restoration. I have done this successfully before with the 3M kit on another car. Since they weren't in too bad of shape, I bought the Turtle Wax kit, it worked well on the driver side but still cloudy on the passenger side. Tried the 3M kit using the drill and still the passenger side is cloudy.
I know that I've removed much/all of the oxidation ... you can see the small imperfections are mostly gone. But still cloudy, just on one. As far as I can tell, these are original, both HELLA. Should I try the 500/800/3000 grit cycle again? At this point I feel like I've definitely sanded enough. Just very odd that one side is OK with minimal work and the other is still cloudy. thanks for any advice |
