      04-24-2025, 07:20 PM   #1
vrships
Drives: X3 M40i, M4C G82 LCI
Wrinkled IOMG paint due to heatgun misue
I was trying to remove some scuff on the PPF on the lower rocker panel piece. Turned out the scuff was too deep to self heal and I totally messed up overheating the area. Now when I peeled of the PPF, the underlying body paint has deep wrinkles in it. Not sure it's the clear coat or all layers.
It's about 2*2" area. I am gonna try sanding compounding and polishing but the grooves feel deeper than typical orange peel I doubt they can be fixed this way
This is a plastic piece p/n (51-77-8-084-240). If I take this part off to have a shop repaint it, how much does this usually cost?
      04-24-2025, 07:42 PM   #2
Portimao Blue M440ix
Portimao Blue M440ix's Avatar
271
Drives: Bmw m440ix g22
If you reapply new ppf would it hide the defect you think.
      04-25-2025, 07:31 AM   #3
John in VA
Drives: 2015 228i M Sport
Could be $150-200+ in your area. Most shops have minimums.
      04-25-2025, 07:39 AM   #4
tracer bullet
tracer bullet's Avatar
I'd be curious to know if it can be smoothed out.
* Maybe similarly, with heat
* Maybe sanded, if it doesn't go all the way through
There's a part of me that says go for it, it's already messed up, if the methods fail it's in the same state. There's another part that says live and learn, if it's reasonably out of site only you will ever see it, and forget about it.
      04-25-2025, 09:45 AM   #5
slilley
Drives: 2023 X5, plus others
My $0.02 cents: learn to ignore it, and treat this mistake as a life lesson. It looks like it would only be noticeable if you are looking for it, and the car is clean. Nice color, btw!
      04-25-2025, 10:57 AM   #6
RCKYMTN M34OI
Drives: 2020 M340i
With some wet sanding and re-application of PPF I think you could make that almost undetectable. That being said I would take it to a detailer experienced in wet sanding. That panel is plastic so you can't measure paint depth to see how much you're removing.
      04-25-2025, 11:53 AM   #7
BlkGS
BlkGS's Avatar
5289
Drives: BMW X5 M50i
I'd be tempted to heat it and see what happens. Then try sanding it down. Then once neither of those work, get it repainted.
