04-30-2025, 06:56 AM | #1 |
![]() ![]() ![]() ![]() 495
Rep 915
Will Ceramic or Graphene on Windshield fill in pits?
If I graphene coat my front windscreen, will it fill in the tiny pits that shine when driving into the sun?
04-30-2025, 07:02 AM | #2 |
Rep 9
Hi, no it will not you will need proper window adhesion to rectify this
starlights495.00 afadeev1765.50 |
04-30-2025, 07:13 AM | #3 |
![]() ![]() ![]() 5002
Rep 5,076
Agreed, it won't "fill in" anything. It's far too thin.
04-30-2025, 08:43 AM | #4 |
![]() 207
Rep 180
There's no practical way to improve a pitted windshield (besides replacement). The best you can do is to keep it clean, but that won't help with pitting. I've seen people say you could polish out the pits, but that's never successful. I use a windshield film (similar to PPF) on my windshield on my garaged "fun" car, but that film needs to be replaced every other year on a car driven just 5K miles a year - so it would probably require a nearly-annual replacement for a daily driver seeing 10-12K miles a year. Still, it's nice when they peel off the film to replace it - only the biggest stones have pierced the windshield film enough to leave any windshield pitting behind. I've used ClearPlex and ExoShield windshield films so far, and will probably try the new Xpel film next.
starlights495.00 StradaRedlands8537.00 |
04-30-2025, 08:48 AM | #5 | |
Rep 915
![]() Edit - thanks for the info on the films. Just looked at Clearplex website and it states that it blocks 99% UV rays. Wondering if it will be good for on top of sunroof to block heat? Last edited by starlights; 04-30-2025 at 08:56 AM.. |
slilley206.50 |
04-30-2025, 09:05 AM | #6 |
![]() 1414
Rep 2,575
I've read post about tinting sunroofs & how it's not recommended. Don't know if the same applies to a clear layer. They tend to explode on their own!
starlights495.00 |
04-30-2025, 09:10 AM | #7 |
Rep 915
04-30-2025, 10:37 AM | #9 |
Rep 5,076
I put some on my (new) Z4 windshield. Shortly after the rest of the paint. I learned that it's far less forgiving, and not as easy as their videos make it seem.
Application is of course apply, wait a bit, buff off the majority with one MF towel then perfect it with another. For the paint it's kind of easy, and looks incredible. On the window, driving towards the sun, you see EVERY little streak and imperfection that you can not see in the paint. I ended up cleaning it (standard light polishing process, using Meguairs Scratch-X) off to have the window be perfect again. So if you do go for it, be sure to do a super good job at the removal step. |
04-30-2025, 10:57 AM | #10 | |
Rep 915
05-05-2025, 06:37 PM | #11 |
Rep 915
On a whim I did actually apply a single coat of Adams Graphene to my front windshield and ensured that I leveled it with a vengeance
05-06-2025, 12:02 AM | #12 | ||
![]() 1766
Rep 2,865
Most ceramic coatings are 0.5-1 mil thick. For comparison, outer layer of laminated windshield glass is typically around 2.1mm to 2.5mm, or 82-100 mils thick. Clear-coat is ~5-7 mils. As you can surmise, ceramic coating will not fill scratches or chips in either clearcoat or glass. Quote:
I've also tried applying multiple water beadings coatings to windshields in all four (4) of my cars for many years. None last longer than ~6-9 months when exposed to wiper abrasion. Of those that I've personally tried, I find all of the following to perform similarly, with the only distinction being how long they last before requiring re-application: Griots glass ceramic < RainX < Griots rain sealant < Aquapel Glass Treatment < Stoner Invisible Glass Ceramic. GYEON Quartz QuickView is next in my "to try" queue. HTH, a
'15 F80 M3 (SO/SS)
05-06-2025, 06:41 AM | #13 |
Rep 624
I have one pit that's a bit distracting and have been looking for a way to fix it. I have wondered about several coatings, but I don't like the idea of coating my windshield with something. I need a spot fix, but it's not large enough to fix the standard way IMO.
05-06-2025, 07:32 AM | #14 |
![]() 3534
Rep 3,078
I’ve got windshield film on 2 of my cars right now. It’s a love/hate relationship.
I love knowing there’s a pristine windshield underneath the film. I hate seeing the wiper micro-scratching on the film. It’s pretty delicate stuff. It’s supposed to self-heal, and it might, but my OCD struggles when the sun hits the windshield. Not as bad as permanent pits in sunlight, however. I live in the land of 365 days of gravel and sand on the pavement, trashing everybody’s paint and windshields.
///M
StradaRedlands8537.00 slilley206.50 |
05-06-2025, 11:33 AM | #15 |
![]() 155
Rep 124
I used the Eastwood polish kit on a windshield that had thousands of tiny little pits from 20 years on the road. Kind of like it had been sandblasted. It was awful driving into the sun.
The improvement did not make it look like new, but it was certainly enough to make it easily tolerable and it was no longer bad enough to consider a replacement. |
