      05-01-2025, 03:20 AM   #1
leasehackr
Drives: X5, 530e
Griot’s G9 + BOSS Correcting Cream Before CQuartz UK 3.0 – Need Advice
Got the Griot’s G9 2-Step BOSS Kit which came with free BOSS Correcting Cream and BOSS Finishing Sealant.
My new M440i came without the hood film—now has swirl marks, spider webbing, and a few scratches.
Plan:
  1. Correct with BOSS Correcting Cream
  2. (Optional?) Finishing step – Use BOSS Finishing Sealant or a quick pass with CarPro Essence (I have half a bottle)
  3. Wipe down with CarPro Eraser
  4. Apply CQuartz UK 3.0
Question: Should I use BOSS Finishing Sealant or Carpros Essence polish before coating, or skip both? Want proper prep for best bonding.
Thanks!
      05-01-2025, 08:20 PM   #2
sean2648
sean2648's Avatar
Drives: 2015 335i
If you are going to be applying a coating you don't want to use either of those beforehand because they both have protection built in already. After the correction stage you want to use some finishing polish without any fillers or protection in them. The coating willl be your protection.
We don't use or carry Griots products in our shop, but plenty of other options we could recommend for the finishing step
'15 335 M Sport 6MT /// FBO /// Custom Tune /// Custom Interior
Instagram /// Build Thread
      05-01-2025, 08:47 PM   #3
spazzz
spazzz's Avatar
193
Drives: 2008 535xi MHD&XHP,2013 X1 35i
A very common step used is Final stage polish with Essence Xtreme gloss primer
followed by UK3.
Carpro has stated there is no need to paint prep wipe after Essence but most people do.
It is what I generally use as my coating routine with UK3.
Essence plus is what you don't want to use before coating since it is a sealant with fillers.
      05-01-2025, 10:10 PM   #4
RCKYMTN M34OI
Drives: 2020 M340i
followed by UK3.
^ This. you can use Carpro essence prior as it is the primer polish to UK3. Don't use the Griots sealant.
      05-01-2025, 10:41 PM   #5
leasehackr
Drives: X5, 530e
Which finishing polish do you recommend?
Carpros lists this as a semi-permanent filler and primes the surface for coating.
https://carpro.global/product/essence/
followed by UK3.
Correct
The orange bottle I have
Last year, I used this for correction on the new X5, it removed some defects, but not all. This time, I need to step up the cut/defect removal by using Boss Correcting Cream. Saw good reviews about it.
Make sense
This is the updated plan.
Plan:
  2. (Optional) A quick pass with CarPro Essence (Orange bottle). I will see if there is a need to enhance gloss.
  5. For the 2nd layer, since I have half a bottle of CQ.UK left over from X5 application. Will be applying Gyeon Q˛ CanCoat EVO after 24 hours.
