05-25-2025, 08:14 PM | #1 |
![]() 234
Rep 1,208
Is this rust or oxidation?
Do I need to remove this rust before using drcolorchip?
I tried ironx but it didn't really do anything. Want to know if it's okay to paint over the chip or somehow remove the rust or whatever this is.
sent from bimmerpost Android app
05-25-2025, 08:45 PM | #3 |
![]() 234
Rep 1,208
05-25-2025, 08:56 PM | #4 | ||
![]() 1766
Rep 2,863
I do see two (2) area of concern: 1). Paint chip edges are jagged and in some place raised. You really will want to sand-away all raised edges and areas of the old paint that are no longer firmly adhering to the primer. 2). Top picture shows a deeper cut that very likely goes through the primer. Sand that area as well until you get to the shiny metal. Quote:
Also, if you neglect to start with an even working chip surface, sanding it level with the remaining paint plane after you fill it in will be that much trickier. HTH, a
'15 F80 M3 (SO/SS)
05-25-2025, 11:48 PM | #5 | |
![]() 234
Rep 1,208
05-26-2025, 09:58 PM | #6 |
![]() ![]() ![]() 718
Rep 436
Those are tiny chips that are zoomed in very close on a macro shot. In my opinion, sanding the edges of those tiny chips will be tough to do in such a small area without making a bigger mess. If it were my car, I would dab touch up paint in there and move on. You take 400 grit to that with your finger and you are going to turn a rock chip into a dime size patch that will be hard to deal with for the average person.
tracer bullet5000.00 DrVenture2057.50 |
05-26-2025, 10:05 PM | #7 | |
![]() 234
Rep 1,208
Yes the pic was macro. I'll likely take more pics (before and after) non zoomed in macro ha.. |
05-27-2025, 07:11 AM | #8 |
![]() ![]() ![]() 5000
Rep 5,075
Rust is oxidation, actually, but agreed it's likely not either. Also agreed to dab the repair and not sand to a larger area. Best case the repair works. Worst case it doesn't and then you sand to the larger area (which will indeed be far harder to make look right, if ever).
05-27-2025, 10:54 AM | #9 |
![]() 0
Rep 6
Hi, I don't know if there's a more relevant section, but if so, I can't find it. My car was imported from Germany, where they use salt to remove snow, so some parts have some rust. I've seen some rust-removing paints out there. Has anyone tried it? Thanks.
05-27-2025, 03:20 PM | #10 |
![]() 234
Rep 1,208
Osphos is one you can try
05-27-2025, 09:16 PM | #12 |
![]() 234
Rep 1,208
05-27-2025, 09:17 PM | #13 |
![]() 234
Rep 1,208
Thanks all for the tips and feedback. Think I will pass on sanding and just use the drcolorchip kit and move on.
I'll post a full review of the process in the coming weeks. |
