05-30-2025, 12:39 PM | #1 |
![]() 402
Rep 1,681
Scratch removal gone wrong
I tried fixing a scratch on my car and sanded way too far. Looks like I went through all the clear coats, paint and primer??
I have the matching paint via Dr colorchip. Tried applying it and polished but still have the same problem. Suggestions?? |
05-30-2025, 12:50 PM | #2 | ||
![]() 1764
Rep 2,861
HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 05-30-2025 at 01:09 PM.. |
RMNB402.00 |
05-30-2025, 12:59 PM | #5 |
![]() 1502
Rep 1,687
Oh, damn. Any pictures of the original scratch? It feels like you were far too heavy-handed with this but I also don't know what the scratch was like. Beyond the obvious issue, it looks like there are sanding scratches outside the crater as well.
You 'could' fill this in w/ Dr Colorchip (even though it is not intended for large area repair) but you are beyond simple rock chip repair kits at this point and into 'multi-stage repair' territory. You could DIY it but....you are probably better off going to a body shop (no offense). On the plus side, you got rid of the scratch.
- Jeff
bosstones' flickr |
05-30-2025, 01:05 PM | #6 |
![]() ![]() ![]() 435
Rep 502
Agreed, I see this as a successful job, the scratch is definitely gone.
2022 BMW M550 Xdrive (stock).
Jaizero161.50 B58-M340iX340.00 |
05-30-2025, 01:12 PM | #7 | |
![]() 1764
Rep 2,861
The trick is to wrap paper over horizontal block that overlaps the repair area. Then hold the block as horizontal to paint plane as possible.
This way you sand only over the touched-up paint spot, and not the healthy paint areas. Start with wet-sanding, and Go Slow! Quote:
Start with 1500, and see if that does the trick. If not, go one level more coarse, or just go slow! HTH, a
'15 F80 M3 (SO/SS)
05-30-2025, 01:31 PM | #8 | |
![]() 402
Rep 1,681
05-31-2025, 10:28 AM | #9 |
![]() 205
Rep 180
This! Fixing a scratch with Dr. Colorchip *should* have been a relatively easy job, but you've created a problem FAR worse now. I'd suggest, with all due respect, that you put down any sandpaper or other tools, and hand the job over to a professional.
RMNB402.00 ultrared93113.50 |
05-31-2025, 10:50 AM | #10 |
![]() 193
Rep 196
These are the times where you can't break it because it's already broke.
Like afedeev said use 1500. Hell I hate trying to get rid of 1500 because it takes 2000, 2500, 3000 and some compound/polish after. But you have to do what you gotta do. Definitely use a firm foam sanding backing pad and don't press hard. Make sure you get the colorchip paint above the existing paint level before sanding> Let the experiment begin |
RMNB402.00 |
05-31-2025, 01:14 PM | #11 |
![]() 402
Rep 1,681
You're probably right however my next attempt was to apply primer after once i buffed it smooth. I will try paint tomorrow after dries thorougly and see where this gets me.
StradaRedlands8532.50 slilley205.00 |
05-31-2025, 09:23 PM | #12 | |
![]() 1489
Rep 1,143
Two is One and One is None
06-01-2025, 10:54 AM | #14 |
![]() 432
Rep 1,036
Sorry to see this!
You will most likely won't be able fixed this yourself. Especially after sanded down all the way to primer layer. Definitely recommend bring it to the shop! They will most likely have to respray the whole bumper. I dont know the cost but won't be cheap but not crazy expensive. |
06-01-2025, 03:54 PM | #15 |
![]() 402
Rep 1,681
Might look at a few estimates for a reality check but more than likely diy to the (n)th degree until I cave.
$500 seems like a number I can deal with from a professional paint shop otherwise higher than that just feels like a rip off. |
spazzz192.50 |
06-01-2025, 10:40 PM | #17 |
![]() ![]() ![]() 20494
Rep 11,633
Wow, I applaud your tenacity in trying to remove that scratch.
///M Power-Belgium80253.50 |
06-02-2025, 08:25 AM | #18 | |
![]() ![]() ![]() ![]() ![]() 2227
Rep 990
There's a saying I love to use: Education will never be as expensive as ignorance. Good luck.
"Education will never be as expensive as ignorance." Last edited by DocL; 06-02-2025 at 09:09 AM.. |
DrFerry8268.00 |
06-02-2025, 10:35 AM | #20 | |
![]() 402
Rep 1,681
06-02-2025, 11:24 AM | #21 |
![]() ![]() 345
Rep 397
It may seem obvious now, but when doing scratch removal, it's usually best to call it "good enough." Without a paint thickness gauge, you have not idea how deep into the clear you've gone.
I have a scratch I was dealing with and I personally stopped after a few passes of medium/heavy compound and then a polish. It could probably be better, but I don't know how much clear I removed so far, and I don't want to risk it. Ironically, I need to visit a "pro" because I think the scratch may also be pushed in/dented, I can see some distortion in the damaged area at the right angles. So...need to call in the pros. If for me PDR gets it 90% of perfect with a few residual scratches that you can barely see unless you look, that's probably worth a couple hundred vs me experimenting further. |
06-09-2025, 09:19 AM | #22 |
![]() 402
Rep 1,681
estimate
[ATTACH]undefined[/ATTACH]Estimate looks reasonable. Thoughts?
$654.48 ( 4.3hrs body labor, 3.5hrs paint labor- $57/hr ), Paint and Body supplies, etc. Last edited by RMNB; 06-09-2025 at 09:30 AM.. Reason: update |
