06-16-2025, 01:47 PM | #1 |
![]() 15
Rep 61
traction control problem after mouting continental tires
Hey everyone,
I've got a BMW G26, and after putting on Continental Sport Contact 7 tires, I'm getting an odd issue. When I hit around 150 km/h and give it about 50% throttle, the traction control light flashes and the engine power cuts out. It doesn't happen every time, but I'm thinking it might be tire-related. Any ideas what's going on? new tires are the exact same spec of the previus tires i had i already have put my old tires and there is no issues this is the response from continental (outrageous): Good morning. We have examined the information provided and can confirm that the reported phenomenon is not attributable to manufacturing defects of the tires, but rather to incorrect equipment. Since this is a BMW Xdrive vehicle with different sizes between the two axles, it is practically mandatory to install BMW-approved tires, i.e. "starred" tires, as recommended by BMW itself. These tires have lower manufacturing tolerances than the ETRTO standard ones, to adapt to the characteristics of the Xdrive transmission, which in turn has limited tolerances. Installing non-approved tires can lead to malfunctions of the vehicle's traction/stability control systems and, potentially, damage the mechanical parts of the transmission. We attach a technical sheet that deals with the topic and we recommend that you only install BMW-approved tires on the vehicle. Last edited by haru69; 06-18-2025 at 07:31 AM.. |
06-16-2025, 03:14 PM | #2 |
![]() ![]() ![]() 6613
Rep 12,265
Brand new tires still have the release agent from the mould that reduces traction for maybe 100 miles. If you have driven more than that I have no idea unless you also changed tire sizes.
Westside Guy8713.00 alex23643575.00 |
06-16-2025, 03:26 PM | #3 |
Riding the knock sensor
3711
Rep 2,324
Drives: 21 X5MC | 23 M4CSL
Assuming you chose OEM sizes you might need to reset TPMS. Manually check/adjust pressures before doing the reset. Other possibility is tire diameter mismatch - xDrive requires diameter to be within 1% front to rear and will cause error codes driving at high speeds.
shawnhayes2104.50 |
06-16-2025, 04:33 PM | #4 | |
![]() 15
Rep 61
Today I have put my old tires and there is no traction control issue anymore So I guess these tires have some type of defect ? |
06-16-2025, 04:38 PM | #5 | |
![]() 15
Rep 61
The pressure is perfect I went to both the BMW dealership and where I bought these tires. Both told me one tire has a slightly different diameter, which is why the traction control senses one tire slipping more than the other and cuts power while accelerating |
06-16-2025, 07:40 PM | #7 |
![]() ![]() ![]() 5000
Rep 5,074
Westside Guy8713.00 |
06-17-2025, 01:08 AM | #9 |
![]() 15
Rep 61
tracer bullet5000.00 |
06-17-2025, 08:28 AM | #11 |
![]() 218
Rep 92
Drives: 2010 Z4; 2008 118D
I'm running the same tires and no issues...thus far
06-17-2025, 09:23 AM | #12 |
![]() 15
Rep 61
06-17-2025, 09:45 AM | #14 |
![]() 15
Rep 61
06-18-2025, 02:59 AM | #17 |
![]() 15
Rep 61
Well I guess I will never buy continental anymore that's their response 😅
Good morning. We have examined the information provided and can confirm that the reported phenomenon is not attributable to manufacturing defects of the tires, but rather to incorrect equipment. Since this is a BMW Xdrive vehicle with different sizes between the two axles, it is practically mandatory to install BMW-approved tires, i.e. "starred" tires, as recommended by BMW itself. These tires have lower manufacturing tolerances than the ETRTO standard ones, to adapt to the characteristics of the Xdrive transmission, which in turn has limited tolerances. Installing non-approved tires can lead to malfunctions of the vehicle's traction/stability control systems and, potentially, damage the mechanical parts of the transmission. We attach a technical sheet that deals with the topic and we recommend that you only install BMW-approved tires on the vehicle. |
06-18-2025, 07:06 AM | #18 |
Rep 12,265
I am running Conti EC Sport 02 on my 2018 M5. Not Star spec and no issues. In fact, BMW uses the same Conti tires on the M5s at its Performance Centers.
But yes, if the front to rear diameter difference is more than about 1%, there can be traction control issues. At 90, tires are hotter. Could be the rears are much hitter than the fronts. Heat causes expansion. Maybe there is some way to check this and maybe use inflation pressure to fine tune. |
06-18-2025, 07:15 AM | #19 | |
![]() 15
Rep 61
i have heard from other people with my same car with these tires and they have no issues.. |
06-18-2025, 08:27 AM | #20 |
Rep 12,265
Could there be a different issue than the tires? I know the timing makes the tire change the prime suspect. Any tuning or other work done at or around the same time? Damaged ABS sensor can operate intermittently, for example.
06-18-2025, 09:58 AM | #22 |
3711
Rep 2,324
This whole story is weird. I'm having trouble believing one tire was made >1% larger than the other in the same labeled size. I'm not surprised by Conti's response to use star tires, but interesting that they claim tighter manufacturing tolerances - I've not heard that before. 'Kook FTW. Maybe try again with Michelin.
shawnhayes2104.50 DrFerry8268.00 |
