06-18-2025, 06:25 PM | #1 |
![]() ![]() 897
Rep 2,435
Best way to comb my fins
I’ve come to the realization that placing discreetly chicken wire type of protector behind the kidney grills is the way to go to prevent your condenser fins from getting pummeled by stones.
If you’re looking at the photo, I can use a fin comb in some areas only, because a large number of fins are bent way beyond it. So I’m planning to painstakingly one by one pull the fins back out where I can insert the fin comb between them. Would it be easier, and more efficient, to push them out from the other side of the condenser coil?
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
06-18-2025, 06:32 PM | #2 |
![]() ![]() ![]() 6613
Rep 12,265
You can certainly make an improvement by painstakingly combing the fins, but you won’t make the heat exchanger like new. I have done this on some cars. The fins are staggered so you are really going row by row and nit combing. I use a small thin screwdriver and a small pair of needle nose. Have fun.
As for the screen, too fine a mesh blocks airflow. I don’t know what the ideal mesh square is. 1/4? 5/16? 3/8? Have thought about this myself. You can make your own, but Zunsport and other companies may sell premade ones. |
fe7565896.50 StradaRedlands8532.50 |
06-18-2025, 07:09 PM | #3 | |||
![]() 1766
Rep 2,861
Rally-cross much? Quote:
How much do you earn per hour? Quote:
OTOH, if the car is nowhere close to overheating and you live in the colder climates, why not leave it alone? HTH, a
'15 F80 M3 (SO/SS)
fe7565896.50 |
06-18-2025, 07:24 PM | #4 | |
![]() ![]() 897
Rep 2,435
As far as the protective mesh. I saw some photos of people doing it, and it didn’t look ghetto. I will try to look it up to see what size mesh they used. But there is a valid concern, as far as the size and blocking airflow, otherwise BMW would’ve had these coming installed from the factory.
06-18-2025, 07:31 PM | #5 |
![]() ![]() 2329
Rep 1,968
Drives: '25 M240xi
Don't bother, you won't notice any improvement and your time/money would be better spent replacing the part.
I know it "looks" like all those bent fins are hurting performance of the Exchanger, but I promise its nowhere near as much of a performance hit as you think. Maybe 5% loss in effectiveness
06-18-2025, 07:32 PM | #6 | |
![]() ![]() 897
Rep 2,435
I don’t mind trying to straighten out as many as I can…I’ve been known to spend days on $100 retrofits ![]() I agree with you, the best thing would be to replace the condenser coil, But I think I can restore the majority of lost airflow, which should keep me still safely within the design parameters of BMW. Even now I’m not experiencing any overheating issues.
06-18-2025, 07:40 PM | #7 | |
![]() ![]() 897
Rep 2,435
However, I think it's worthwhile to check into a protective mesh that looks and works fine. And DO NOT USE high pressure water jet to clean your coils. Use low pressure.
06-18-2025, 07:48 PM | #8 |
Rep 12,265
I’d price out a condenser. On my 2018 M5, I also have heat exchangers in front of each front wheel fed by ducts and they are beat up as well. I spent some time repairing fins while I had the bumper off to install yellow DRL and supplemental intercooler heat exchanger, but will probably just replace the ones with damaged fins in a few years. Maybe as a 10th birthday present to the car. The M5 has an oil cooler, transmission cooler, AC condenser, two engine coolant radiators, and three intercooler heat exchangers (I added the third). No power steering cooler because it is electric power steering.
