      06-20-2025, 03:14 PM   #1
JResman
Drives: E92 330d, E60 530d
Airbag restrained system fault
Hi guys
I have a weird problem with my E60 airbag restraint system. The scanner is showing two faults:
9AF4 seatbelt tensioner driver too high
9AFF safety battery terminal too high
I put a resistor on the battery cable a couple of months ago since it is a common fix and it fixed the issue and now it came back. I messured the resistance today and it was around 0.3 - 0.4 ohm which should be correct. I also messured the resistance on the seat tensioner and again should be the correct (0.3 - 0.4 ohm)
Am I doing something wrong or could it be the airbag module? Not getting any other airbag faults.
Thanks in advance
