      07-03-2025, 05:40 PM   #1
whenasked
Drives: E90/G12 740xi
Bowers and Wilkins sound quality
Since a week, the audio from B&W system in my 2021 740 feels underpowered or not having enough base.
I have an appointment on Monday. Any diagnostic procedure I could do myself in the interim?
Thanks
      07-03-2025, 07:42 PM   #2
BlkGS
BlkGS's Avatar
5285
Drives: BMW X5 M50i
What kind of music do you listen to? They don't do super deep bass for rap.music and similar.
      07-04-2025, 12:03 AM   #3
Tejas1836
Tejas1836's Avatar
1489
Test Your Speakers Like A Cambridge Audio Engineer
https://www.cambridgeaudio.com/usa/e...utm_campaign=0
Two is One and One is None
      07-04-2025, 07:18 AM   #4
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I had to put it in I think it was studio mode with surround on to get it where I wanted. I will double check my settings and post on it.
      07-08-2025, 01:30 PM   #5
whenasked
Update, service advisor reporting that both subwoofers are bad and will need to be replaced. Thanks to extended warranty
      07-09-2025, 01:33 AM   #6
B&W not all it's cracked up to be.
CGG284.50
      07-11-2025, 06:59 PM   #7
whenasked
Dealer replaced subwoofers. Still feels crappy. Back to dealer. I asked them what are the chances of both subwoofers going bad at same time and have they checked the amplifier. Looks like gone are the days where diagnostic means finding the root cause rather than throwing parts at it.
      07-12-2025, 02:55 PM   #8
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
Most so called auto technicians are just parts changers. They have no analyzing abilities. Though there is usually one tech who is a shop foreman and most of them know their stuff.
      07-12-2025, 05:07 PM   #9
allinon72
allinon72's Avatar
5161
Drives: 21' M5, 23' X1
Even for the parts changers, the first step is to scan the car in ISTA. An amplifier issue would throw a fault for that system.
      07-12-2025, 06:34 PM   #10
Timmer-Bimmer
Drives: 2026 BMW X5 M60i
2026 BMW X5 M60i  [10.00]
THere is a graphic equalizer. The first thing I would do would be to put the Graphic Equalizer in a U shape so the lowest bass and the highest high are boosted. This made a bit difference for me. Then I need the volume at a least halfway to get a great sound.
I would assume you have already done this and are still having problems with the low bass.
      07-13-2025, 08:36 AM   #11
whenasked
Yes. Front side is clear. Rear side output is boomy and muddy. I had several buddies listening into the car and everyone said something is off.
      07-23-2025, 10:36 AM   #12
whenasked
Update from dealer, amplifier getting replaced
      07-23-2025, 04:58 PM   #13
whenasked
This was the diagnosis: Cause: BATTERY CHARGER SHORT TEST FOUND FAULT CODE. B7F480 AUDIOAMPLIFIER
(BOOSTER): NO CONNECTION. COMPLETED TEST PLAN ANDFOUND THE AMP IS NO LONGER OUT
PUTTING AS MUCH POWER AS ITSHOULD BE. .
Correction: REPLACED AND PROGRAMMED AMPLIFIER TO VEHICLE
W2k302.00
      07-24-2025, 12:47 AM   #14
snowbimmer
snowbimmer's Avatar
2025 M850 GC  [9.83]
...............and?
      07-24-2025, 02:29 AM   #15
W2k
W2k's Avatar
Sweden
302
Drives: 2025 BMW i5 xDrive40
Thank you for sharing the diagnosis and result, it might be of help to someone else having a similar issue.
      07-24-2025, 06:52 AM   #16
Ugly Kar
Drives: E92 to C43 Cab to G42
I think it sucks and not worth it. I'm sure others will disagree.
      07-24-2025, 10:38 AM   #17
T-Dubbs
Coal Troll
210
Drives: '14 F10 535d
but have you heard the HK?
My hybrid burns Diesel & Oil
deleted F10 535d
Tags
bowers and wilkins
