      07-03-2025, 07:04 PM   #1
aidanrodonne
Drives: 2011 bmw 335i xdrive
E92 2011 335xi 2C57 code HELP
My 2011 335xi keeps randomly throwing a 2c57 code at different rmps and times throughout each time I drive my car even after I clear it, I have replaced a few things which I would have thought would be related to the code suck as my charge pipe, boost converter, and my (MAP) or boost pressure sensor, and from what I can tell the car doesn’t have a boost leak. So what could my issue be?
      07-04-2025, 10:16 AM   #2
pikkagtr
Go Spurs Go
pikkagtr's Avatar
4061
Drives: '22 GR Z4 Coup '06 Z4M Rdster
Have you done a pressure test to verify no leaks?
If so it may be the pressure converter
Genuine BMW - 11747626351 - Pneumatic Wastegate Actuator
      07-04-2025, 10:18 AM   #3
aidanrodonne
I replaced my pressure converter and it never solved the issue, and I have not pressure tested the system, I have just smoke tested the cars entire boost system.
