      07-10-2025, 11:11 AM   #1
josh r
Drives: bmw 118d 2017 m sport manual
Mystery noise
I have a bmw 118d 2017 m sport manual with 60k on it full bmw service history,
The car is making a noise from the engine like a drumming noise it gets faster when you increase the rpm and you can feel the vibration through the clutch pedal?
I have had the dual mass flywheel and clutch changed and also drained the oil to check for metal particulate there is nothing also checked crankshaft thrust bearings by pulling on pulley side and flywheel side there is about 1-2 mm of play.
Can’t find the source of the noise any ideas ?
