Hello can some help me I’m trying to run some 20 in hre classics on my 2017 bmw m6 f06 grand coupe and I would like for someone to help on a flushed fit mine please. I have hre lowering springs and it the comp shocks.
This the factor wheel set up
✅ 2017 BMW M6 Gran Coupe – Wheel Specs (Factory 20")
📏 Wheel Size (Width x Diameter)
Front: 9.5J x 20"
Rear: 10.5J x 20"
↔️ Offset (ET)
Front Offset: ET31
Rear Offset: ET19
🧵 Thread Size (Lug Nuts)
M14 x 1.25
🔘 Bolt Pattern (PCD)
5x120 mm
🎯 Center Bore (CB)
72.6 mm
🛞 OEM Tire Size (Typically Fitted with 20" Wheels)
Front Tires: 265/35ZR20
Rear Tires: 295/30ZR20
I was told to run this and
I’m trying verify a perfect offset with no
spacers I want flush to my body panel and this is what they are telling me can you verify if this seem correct with my car
Front 20x9.5” ET20
Rear 20x10.5” ET5
2.4KVIEWS
0REPLIES
0APPRECIATES
1ACTIVE PEOPLE
08-22-2025LAST POST
08-22-2025
08-22-2025
hschiro_
REP
15
POSTS
