      02-11-2009, 10:17 AM   #1
hl0m4n
hl0m4n's Avatar
Question Windows XP Pro Help Needed
when you press "start"--> all programs i have 2 complete rows and i keep getting this message saying some icons may not appear (b/c they are all the way at bottom of row 2).
is there a way to extend this and have a 3rd row?
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      02-11-2009, 10:52 AM   #2
MadDog
Careful, I Bite.....
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Put your programs into different folders - I have ones for Applications, Utilities, Games, Accessories, etc - and you won't have that problem.
      02-11-2009, 11:03 AM   #3
hl0m4n
hl0m4n's Avatar
how do i create folder in the menu? i right click and all i get are open, explore, rename, delete, sort by name, and properties?
PS: how are the 1tb external hard drive now days? reliable?
      02-11-2009, 11:13 AM   #4
Rick
Stackin' Chips
Rick's Avatar
Drives: 2008 AW M3 Coupe
right click start menu, then click explore.
Hard drives with moving parts (non-ssd drives) are not very reliable in the long run, i.e. ~5-10 years. It is one of the most common failing parts in a system along with the PSU and optical drives.
      02-11-2009, 11:16 AM   #5
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Go to Start -> Settings -> Taskbar and Start Menu. Click on Start Menu tab and then click on Customize button. Click on Advanced button, and you should see an Explorer-type window showing your Start menu.
You can also just navigate to C:\Documents and Settings\yourname\Start Menu.
Then, add the folders you want, and then drag and drop the program shortcut links into them.
I don't have any external hard drives, so I wouldn't know.
      02-11-2009, 11:17 AM   #6
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Yep. A lot easier than the two ways I posted. Thanks.
      02-16-2009, 10:08 PM   #7
hl0m4n
hl0m4n's Avatar
thanks alot guys
