      11-11-2009, 06:18 PM   #1
hl0m4n
hl0m4n's Avatar
Question My Comp Is Busted... Help Needed
i turn on my bros comp today and it doesn't seem to boot. it was working just fine yesterday (windows xp pro).
1. i turn on the comp
2. it goes to the screen saying it couldn't boot windows and gives me options of botting in safe mode, start windows normally, etc.
3. i try the start windows normally first, then the most recent working setting, followed by safe mode (does the windows xp cd need to be in the cd rom drive to do this?)
4. i try all the options and what happens is it goes to the windows xp screen then i get a quick blue screen with some type of characters, numbers, etc (too quick to read) and the comp reboots again and when it does it brings me back to the option page with the start windows normally, etc.
5. i pick another option and same thing happens quick blue screen, reboots, and brings me back to the screen with options.
what is wrong? help much appreciated. thanks.
found someone with exactly what i had but still not fixable: http://www.ozzu.com/hardware/machine...t40747-15.html
http://articles.techrepublic.com.com...1-6031733.html
if i run the repair through the windows cd will that delete what i have on the harddrive or just fix and repair window files?
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      11-11-2009, 06:20 PM   #2
xbook
xbook's Avatar
Drives: '14 EBII M235i & '06 R53 GP
2006 MINI Cooper S GP  [0.00]
2014 BMW M235i  [0.00]
2008 E82  [0.00]
As your attorney I highly recommend drinking heavily, that should sort this out. Drugs might help too.
      11-11-2009, 07:51 PM   #3
SantaPimp27
SantaPimp27's Avatar
Drives: Slow homie
get a mac
      11-11-2009, 07:58 PM   #4
quagmire
I am Gundam
quagmire's Avatar
215
Drives: 2017 Camaro 2SS
Originally Posted by SantaPimp27 View Post
get a mac
^ This. Best fix for any Windows problem.
      11-11-2009, 08:11 PM   #5
backtofront001
Drives: 2012 AW 135i
that means if ur 335 has fuel pump problems, the best solution is to pick up a reliable honda.
      11-11-2009, 08:15 PM   #6
jpsum
jpsum's Avatar
Drives: 2010 TSX
It sounds like your system files are corrupted or it is infected with a virus.
Normally, the repair option will not delete your personal files, but there is always a chance where you can lose everything in the process of repairing or if you just select the wrong option. Are your files backup somewhere? if so, go for it. If not, I would take the HD out and plug it into another PC and backup the files before doing anything to fix the OS.
      11-11-2009, 08:18 PM   #7
backtofront001
repair is fine, it wont delete ur stuff. Run repair from cd and run command chkdsk and report back
      11-11-2009, 08:48 PM   #8
SantaPimp27
Drives: Slow homie
wrong. moving to a honda is a downgrade.
a better comparison would be, ur 335 is having a fuel pump problem, the best solution is to get an m3
      11-11-2009, 09:59 PM   #9
Zirenz2006
Zirenz2006's Avatar
Drives: G87 M2 Zandvoort Blue
get a mac
I knew this lame response was coming
On Order: 2026 ///M3 Comp xDrive IOMG
Current: 2024 ///M2 Zandvoort Blue
Past: 2021 ///M3 Comp IOMG | 2018 X3 ///M40i | 2012 328i | 2009 335i | 2007 335i Coupe | 2005 545i | 2001 325i
      11-11-2009, 10:08 PM   #10
Inspired
Inspired's Avatar
156
Drives: 335i
Yet, still unreliable..
      11-12-2009, 12:44 AM   #11
backtofront001
you guys are funny...anyways, wonder if the op ran chkdsk
      11-12-2009, 01:43 AM   #12
Comet
Troll Harder
Comet's Avatar
Lebanon
433
Drives: 997 GT3, 997 4 GTS, X6M
I had that problem a while back
either your PC files are corrupted, or you have bad sectors on your HDD.. have you installed any new hardware recently? could be that something messed during installation of it.
Run repair, it should fix it, but chances are it won't.
try reinstalling windows
try plugging it in to another PC as a slave and check for bad sectors. If there are many, then buy a new hard drive, install it as your primary drive and reinstall windows on it.
Run your old hard drive as a slave, grab all your files and forget about the old one.
      11-12-2009, 02:15 AM   #13
SoCali E36
BMW Client Advisor
SoCali E36's Avatar
Drives: X5 40e/e36 M3 Sedan
well said
      11-12-2009, 03:52 AM   #14
boymonkey
Taiwan
44
Drives: slow
Take it to a local shop. They'll diagnose and repair for you.
      11-13-2009, 01:15 AM   #15
bluespeed117
bluespeed117's Avatar
Drives: e90 328i
2007 e90 328i  [0.00]
Yeah
What happens when a mac breaks down? Buy another mac for 2 grand lol.
Muffler Delete/ Tien S-tech Springs / De-badged /BBS LM Reps 19"/ Nexen tires/DTM M5 Front bumper/ Injen Intake/Blacklines/M-tech Rear/Custom Muffler Tips.... More mods to come
      11-13-2009, 01:14 PM   #16
T7R_Sky
"I know you know that I know you know..."
T7R_Sky's Avatar
Drives: Sparkling Graphite E90 328i
2008 E90 328i  [0.00]
I see it more as switching from a 335 to a G35. Its a good alternative... But it isnt always better.
If you're running Windows on a mac does that mean I put the 335 engine in a G35 body? lol
      11-13-2009, 01:29 PM   #17
ragingclue
One cam is enough
ragingclue's Avatar
141
Drives: VF
Yes. Because a mac is a serious performance upgrade. I know cuz I seen the commercials and read about it on teh internet so it must be true.
      11-13-2009, 05:10 PM   #18
hl0m4n
hl0m4n's Avatar
thanks for the help guys, i did the chkdsk came up fine, did the repair with windows cd and even did the other repair the one where it replaces all the files, still nothing.
i just ended up reformatting major PITA but 100% fix
