      02-01-2010, 05:41 PM   #1
Dr_Jones
Drives:
When does your 50mm f/1.8 Sharpen up
Is the 5.6 neighborhood reasonable for this lens...or do i have a shitty copy?
I took a whole mess of shots at 2.2 -2.8 this weekend of my future nephews playing bball indoors (which is a nightmare because of the cycling lights) and very few pictures have anything sharp in them at all.
Just curious what everyones experiences are...i dont remember it being this bad?
Just like Indiana...I love my whip
      02-01-2010, 05:46 PM   #2
BMW F22
BMW F22's Avatar
Drives: ///M235i
Usually it's from about 2.0 or 2.2. If yours isn't sharp between 2.2-2.8 then something is wrong- maybe camera shake, narrow dof or defective lens.
      02-01-2010, 06:49 PM   #3
Dr_Jones
Drives:
hmmm...thats what i figured.
i have a few mixed in that are soft that are 70-200 f4. shutter speed is over 300 for all. maybe its just the fact that there was crap light...
      02-02-2010, 04:14 PM   #4
Derek Zoolander
Drives: 09 E90 M-Sport
It's not an IS lens, so be careful of camera shake.
      02-03-2010, 06:33 PM   #5
Dr_Jones
Drives:
EF 50 1.8 II
Any other 40D shooters have experience with and without high iso noise reduction in the custom functions?
      02-04-2010, 09:38 AM   #6
merlinfe
My other ride has 18,400 SHP. I.B.N.F.E 8251
merlinfe's Avatar
Drives: 2014 MineralGrauMetallic 328d
A few I took with that Combo
Here are a few I took with the 40D and 50mm 1:1.8 MII
and uno mas
If you go to DPReview they have a pretty good review of this lens. Its not the best but it is cheap. I don't feel bad about mounting this on my old Rebel XT and going to the beach or getting into a situation where I would shudder taking the 40D. As for noise, I guess that depends more on the lighting conditions than anything. If you're really really worried about noise you might be better off selling the 40d and getting a 7d. That thing is an ISO monster in comparison.
- Steve
‘83 911
‘98 M3
‘14 328d
      02-04-2010, 12:09 PM   #7
RedBarron
Drives: BMW 440i
I have a nikon but around 2.8 is super sharp.
Current: Porsche Cayman S
      02-06-2010, 03:05 PM   #8
runrider
I pretend to be smart.
runrider's Avatar
21
Drives: '06 325i 6MT 39k
Unless you're a seasoned photographer, it is most likely it is your own error, and not the lens. Post a shot at f/1.8 for us to see.
Possible user errors would be focus issues, like moving the camera after focusing, exceeding the macro focus distance, moving the focus ring accidentally after focus is achieved, etc. Not to mention shutter speed, cropping too tightly, expecting too much, etc.
      02-06-2010, 04:25 PM   #9
Dr_Jones
Drives:
obviously im a beginner but i do shoot about 600 shots a week, am aware of MFD (this shot was certainly outside of it) and handhold a 400 for wildlife all the time (with somewhat decent results). Also its impossible to hit the focus ring on this lens.
AF center point is all i use. Its right on him...i checked and it hits him right below the chin.
      02-06-2010, 06:27 PM   #10
BMW F22
BMW F22's Avatar
Drives: ///M235i
Try putting it on a table or a tripod and shoot something. If you have a remote trigger then use that. Otherwise just put it on the timer mode to avoid camera shake. Also try manual as well as automatic focus. If it comes out blurry still then there's something wrong with the lens/camera.
IMO, it might be the aperture instead of the equipment. If you are too far away from the subject, big aperture won't work that well. Try using a smaller aperture (bigger number) and see. Either that or try shooting the same object at different distances.
      02-08-2010, 07:44 PM   #11
runrider
runrider's Avatar
21
shutter speed? iso?
      02-08-2010, 07:52 PM   #12
1013mm
aka 1013MM
1013mm's Avatar
Hong Kong
1372
Drives: pokingly flush
2009 135i  [8.26]
at around 4 its sharp.
      02-09-2010, 05:51 PM   #13
Dr_Jones
Drives:
500 and 1/250th so low enough and fast enough
      02-09-2010, 07:07 PM   #14
runrider
runrider's Avatar
21
I'm thinking he must have moved after you focused. Try taking a shot of a still target same distance away, from a tripod, and post. If it is still as blurry as this one, I'll blame the lens. I'm expecting it will clear up.
      02-09-2010, 07:19 PM   #15
PNF
PNF's Avatar
Taiwan
183
Drives: 15' YMB F80 M3
50 f1.8II isnt exactly te sharpest lens around anyway, besides, there are too many factors why the image isnt sharp, on top of your camera shake/object movement. maybe higher ISO and thus shutte speed? put out a external flash?
usually, at f2 to f4, it should be pretty fairly sharp.
its a pretty cheap lens and the build quality, glass quality isnt exactly top notch..
2015 F80 Fully loaded (minus the CCB) YMB M3 / Individual Amaro Brown
BBS | KW | Vorsteiner | IND | Akrapovic | BMW CF Performance Interior | Brembo | Eibach
2008 E92 335i (sold)
      02-10-2010, 05:53 PM   #16
runrider
runrider's Avatar
21
Sure its not an L lens, but it should be a LOT sharper than the posted example.
I'd bet dollars to donuts that the kid moved in the time between focus lock and shutter release. Def not motion blur here. 1/250 should be about fast enough - wouldnt give quite this much motion blur.
The other thing that it could be is a Front or back focusing lens, which would need factory re-calibration... but like I said, I think the kid moved after focus was acheived.
OP: Try using Servo focus mode for the next basketball game, and only release shutter when your active focus point is directly on top of the part of the subject you want to be in focus, E.G. his eyes. This lens/camera combo might struggle to keep focus up with a basketball player.
      02-11-2010, 10:33 AM   #17
remmib
remmib's Avatar
Norway
1603
Drives: 2013 F10 520d M-Sport
Yes, it's a focus issue, the f/1.8 has a pretty slow focus. It's sharp when it's get the focus right though.
This is one of the reasons I've got the f/1.4 instead.
      02-11-2010, 05:29 PM   #18
Dr_Jones
Drives:
Thanks guys...Appreciate the feedback.
      02-12-2010, 04:52 AM   #19
runrider
runrider's Avatar
21
He could have the fastest USM focus motor in the world... wouldnt help much if he uses it in the wrong mode!
      02-12-2010, 10:22 PM   #20
Dr_Jones
Drives:
Thanks...servo it is next time. why didnt i think of that
      03-09-2010, 08:14 PM   #21
Andrew@ET
Drives: Red thing
Mine came into day so far soo good but some of the pics arent as sharp as i would of liked. Ill keep playing around with it.
      03-10-2010, 01:53 PM   #22
mogarbage
South Korea
14
Drives: low and slow. bbq style
...after a 3 finger 2 cube single malt scotch
